Thread: Hard to start when cold?
    Welland, Ontario, Canada
    35
    I have a 125m and I have a hard time to start it when it's cold. The plug is always fouled after every try. any tricks? I have adjusted the air/fuel mixture screw last week and the engine was running well.
    Help!
    35
    Do you guys use the choke? It was minus 3 celcius ( 26F) today...
    Apr 2003
    Spanaway, WA
    1,242
    Yes you should use the choke before you go messing with anything. Some bikes don't need it though, my 70 starts up fine without it (lever is broken and the tank doesn't clear enough to get a grip on it). Maybe try bumping the idle up a little.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Apr 2006
    Crestview, Florida
    2,429
    if the plug is fouled each time try not choking it. if it still does it id say the float is sticking, causing it to flood while it sets.
