Results 1 to 8 of 8
Thread: 250r jetting with a 38mm carb
    Mar 2004
    Gettysburg PA
    498
    well i just got a 38.5mm Kiehn carb and i was looking for a ballpark figure as to where i should start with jetting its a 86 250r it has a K&N air filter with the air box lid off Delta v-force 3 reeds and a pual turner hi rev. pipe. the cylinder is stock no port n polish or raised compression (not yet anyways )
    im sure someones running somthing close to this set up and could give me some pointers the main jet in the carb right now is a 175
    hopefully its somewhere close since i wana go riding tomarrow and no cycle shops are open on sundays.
    thanks for anyhelp
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    I'd probably start out at about 165 main, middle needle clip, and a 52 pilot.
    Nov 2006
    AZ
    139
    I'm at 1300ft, mid-60s temps. My 85 has a 38PJ carb, PT High Rev w/ Fat Boy silencer, foam filter with vented lid, Boysen dual stage reeds in stock cage, porting of unknown orgin/style, 180psi compression.
    I'm at a 172 main, DGK needle on 3rd clip position, 58 pilot, 1 1/2 turns out on the air screw. Not sure if I'm dead-on, but it runs clean throughout the rpm range.
    Oct 2006
    Bimringham, AL USA
    7
    Jetting
    I have a 52 pilot and a 182 main jet with a 38.5mm carb. My bike has a stroker kit and is ported a bit. It has a FMF pipes upgraded reed cage, with filter.
    Nov 2006
    Florida
    1,663
    Not trying to go off topic here, but I also have a 86 250R, has an aftermarket pipe and FMF silencer, no motor work ( all stock compression) with just a vented airbox ( with the foam filter).. What size carb would you honda guys recommend using, 38mm? If I di this I take it I would have to put some bosen reeds too?
    Dec 2003
    Lino Lakes, MN
    229
    if you plan on leaving the engine stock, with pump gas etc I would use a 35mm Keihin PWK or a 36mm Keihin PJ. The Mikuni TMX is a nice carb in those sizes as well.
    gravelord is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Hillsborough,NJ
    300
    38mm is GREAT for top end with a stock bore cylinder, oldsking, when i had a stock cylinder and stock head, and i put on a 38mm air stryker carb.... it was AWESOME, it woke it up ALOT..... you will love your self for putting it on, i ran on pump gas too. you dont have to worry about switching over to higher octane unless your head is milled or your ported, or running a big bore.
    youll be fine on pump gas. all two strokes like higher octane though
    Nov 2006
    Florida
    1,663
    Thanks guys, yea I was in debates on bigger, didn't know by how much because I didn't want overkill either lol I'm definetly looking into a 38mm or even a 36mm, which ever I can grab cheaper haha
