Results 1 to 7 of 7
Thread: 70 up and running!
    Nov 2006
    Amishville
    119
    70 up and running!
    Well, I finally got the 70 running decently. The main jet was plugged; still doesn't run perfectly, but well enough for the boys to rip around the yard and proclaim it the greatest machine on earth! Question, should the header pipe be glowing red, or is my mixture off?
    Jul 2006
    wow!!!! red!!!!! super lean!!!!! bad things ahead!!!!!! fix imediatly!!!!
    Nov 2006
    Amishville
    119
    I cleaned the jet out with a cutting torch cleaner after soaking it in carb cleaner; just get a bigger jet?
    Apr 2003
    Spanaway, WA
    1,242
    Yeah, get a few of the next sizes up and see what works best.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Nov 2006
    Amishville
    119
    Thanks, guys. I appreciate the help!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    i would look at timing FIRST......... WORN POINTS WILL RETARD THE TIMING BAD
    Nov 2006
    Amishville
    119
    Yeah, I thought about that. It backfires quite a bit; figured the timing may be a little off.
