Thread: spark problem 1983 honda 200 big red
    Dec 2006
    portsmouth virginia
    3
    hey i am a newbie.i am having a spark issue. i am not getting any spark at all,so i checked plug-good,changed out cdi,changed out pulse generator,but not advance pickup.i was told that it might be the stator,so i found out how to check stator i am getting 200 ohms when i guess i am suppose to be getting between 215 to 245,is 200 ohms good enough to get some kind of spark? also how do i check to see if pulse generator is bad,as well as cdi,as i got both off ebay.also how many stator coils are there behind flyweel. once again 1983 honda big red 200 pull start,no reverse,no safety netural switch -bypassed- thank you in advance
    Sep 2006
    S.E. LA
    700
    Are you SURE your grounding the plug good against the motor when checking for spark?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Dec 2006
    portsmouth virginia
    3
    yes i am sure i grounded it good. i think it is the stator,but i would like to know how to check the rest of electrical
    Scooter77 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    Louisiana
    169
    Have you changed out the spark coil? thats what was wrong with my 125M
    Dec 2006
    portsmouth virginia
    3
    no i have not changed the coil yet,but like i said i checked ohms from the stator and i am only getting 200 when it is suppose to be 215 to 245.i just need to know if 200 is enough to get spark from the stator to the coil.and also how to electrical test pulse generator as well as cdi. and how many stator coils are behind flyweel one or two? thank you in advance
