Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Restoring plastic Fender - ATC Pic's
    Oregon
    2,471
    Question Restoring plastic Fender - ATC Pic's
    Hey guy's just wanted to post up a picture of the Fender i'm in the process of restoring . . .
    i did 220 , 320 , 400 , 600 , 1,000 all wet sanding ...
    Should i do 1,500 & 2,000 ? ? ?
    I still have few deep scratches that i will leave ...
    What Type of Polish can be used ?
    Car polish ? Car Wax ?
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    Yep... You will need to go to 2000.
    mnnmaz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2006
    Arizona (USA)
    222
    Go MYIER its way easier
    Original 85 TriZ owner
    Certified NASA welder PM me if you need any welding I do extended swingarms and everything you can dream of
    Three is Always better then four, unless its with women then four is better then three
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    You should have started with simthing along the lines of 40grit. to really remove the white crap, the WET sanding is whats ganna bring the shine out. So it seems to me you did it wrong. the wet sanding starts from 600 up.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Apr 2003
    Spanaway, WA
    1,240
    Quote Originally Posted by mnnmaz
    You mean Maire? Easier? Maybe. Cheaper? NO.
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by traxxasx
    I'm with him start with 80 grit to remove all the white faded nasty crap. then work your way up. It will almost look nice and red after you get done with the 80 grit, then you are just polishing the surface with the fine stuff. Then buff with a buffer, and compound. Then seal for a shine with a floor wax/polish!
    good luck.
    EDIT: it's fine to wet sand with 80 grit. the water keeps the paper from clogging up.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    NY
    3,185
    I thought starting at 220 was pushing it
    Oregon
    2,471
    The Plastic Fender Was red with some scratch's No Fading what so ever ...
    My under standing is wet sanding is best
    after sanding about 4 hours the Plastic Fender Turned White ...
    So what needs to be done for it to be red again ? ? ?
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    I think all you sanded off was the protective coat. When my fedners were white, i started with 40, you have to dip into it to get a new layer. I dont think you have gone far enough.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Mar 2005
    Newcastle, Australia
    93
    Its funny you guys are talking about this because only yesterday I was mucking around with my rear guard which is always white if it's not drowned in WD40.
    I got a razor blade from a Stanley knife and began lightly scraping off the white. Before my eyes it was coming back to life, beautiful deep Honda red, next I will rub down with 1500 then 2000 and then Ill hit it with the calico buffing wheel and plastic polish.........Ill let you know if it works......looks good so far.
    P.s. you must only lightly scrape with the blade or you will get chatter marks. and keep the blade flat.
    Dec 2005
    Wisconsin
    1,141
    yep you gotta go THROUGH the white junk. Then the red, yellow, green whatever will be nice. when you get it done, don't park it in the sun for days on end.
    1985 Honda 200x...
    May 2005
    Dorset United Kingdom
    1,408
    That white junk is just where the surface has been sanded rough, theres nothing wrong with it. You just need to keep going a bit longer with the finer grades up to 1500 or 2000 and then get a polishing wheel on there.
    Fort Smith AR.
    44
    He said there was NO FADING. That means there was no white junk to sand through. There is no reason to sand with 40 grit. It would probably ruin the fender. This should have all the info you need.
    http://www.3wheelerworldforums.com/s...lastic+sanding
    Sep 2006
    Arizona (USA)
    222
    Exclamation
    Maier baby!!!!!!!!!!!! Give it up and spent the money! How much more time are you going to put into it, you will end up calling Maier so just do it!
    May 2005
    1,408
    What if the guy wants to keep the oem plastic for orginality? Or just to save a buck or $100. Its easy to spend someone elses money
