Thread: 200x kickstarting shaft help
    its fine till you kick it then it stays down. you have to pull it up whats up with that.
    finding a good bike is like finding a good woman, it might or might not happen so hang in there.
    yyz4208@aol.com is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    you will have to replace a spring simple fix
    thanks
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    you could.....
    you could push start it!!!! put it in 5th, pull the clutch in and push it, then release the clutch....but if i were you, i would check and make sure the spring isnt broke (might be a piece in the motor)....that wouldnt be good to have in there.
