Thread: 250r piston / cylinder / head interchangeability
    Feb 2006
    Canada
    36
    Hi there,
    I made some search but I need someone to clarify the things. I have a 85 trike with a 86 trx engine. Which top end combo can I use. I think that it doesn't matter the cylinder year you put, you just have to match the piston year with the rod length? What about the bridged intake?
    Would this setup works: 86 base with shortrod, 86 piston and 87+ cylinder? What about the bridged intake? 87+ pistons are made to match with the bridged intake?
    Should rather use: 86 base with shortrod, 87+ pistons, 87+ cylinder and a spacer plate?
    I know that the 88+ head are cooler and maybe make more compression?
    Thank u folks
    Jun 2003
    englishtown NJ
    2,676
    the following works:
    85/86 crank, any year clyinder, 85/86 piston
    87-89 crank, any year clyinder, 87-89 piston
    87-89 crank, any year clyinder, 85/86 piston, 5mm sapcer plate
    Feb 2006
    Canada
    36
    So it doesn't matter putting a 86 non bridged piston with a bridged cylinder?
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    nope, doesn't matter a bit. I would stay away from the space plate, they add volume to the crankcase and soften power delivery.
    Jun 2003
    englishtown NJ
    2,676
    I like the spacer plate setup, doesn't snap so much. It makes mx riding less tiring, while keeping the same power.
    Jun 2006
    Ohio
    57
    Quote Originally Posted by MathGSR98
    An 85-86 non-bridged piston will work in 87-89 cylinders with no problem, but I would try to avoid running an 87-89 piston in the non-bridged cylinders. The 87-89 piston is full skirted with a window on the intake side. When this type of piston is run with the non-bridged cylinder, the piston can "cock" slightly on the downward stroke and possibly snag on the bottom of the intake port, especially if there's larger piston to wall clearance.
    "Everything's a good idea when you're drinkin'"
    "Without rules, we'd all be livin' in trees, flingin' our crap at each other" - a very wise man
    2003 Lonestar 250R
    2001 Lonestar 250R
    1986 TRX250R restored to new
    1986 TRX250R still in pieces
    2007 TRX450R
    2004 TRX450R
    1999 CR250
    1999 CR500
    1996 CR250
    and many more
    GNCC Vet class
    #102 (WTF)
