Results 1 to 14 of 14
Thread: Clutch question
    Nov 2006
    Halifax N.S Canada
    28
    Clutch question
    This may sound stupid but can someone tell me what the two clutches do on my big red? One is a centrifugal and the other is a manual type. What is the purpose of each? I know that the manual clutch is released during shifting.
    Never judge a man unless you have driven a mile on his trike
    1984 Honda 200es rider.
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    wait 2 clutches??? from my knowledge the reds were automatic.... the left side, I THINK, is the rear brake and the reverse engage handle... correct me if i'm wrong though!
    illinois
    743
    the inner clutch is for the motor/tranny-(inner depending on how you look at it),outer is for the drive-inner is engaged all the time ,the secondary is the "auto"it engages as tension is applied to the weight from the motor out put-- thus making it automatic
    those motors and cases fit different models that was a easy was to make a all internal auto clutch i guess,and motor could be set up for a reg pull clutch with the right parts- i don't know why exactly --lol cheeper than redesigning?
    - never tore one apart so i cant be positive on this - you know how fiche and books are - with out actually doing it
    Jun 2006
    Cushing,Mn
    538
    Thanks jason32,I wanted to know that info too lol!!
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    Hey Davex, Where about are you in Halifax? Im just east of Dartmouth about 25 minutes. I have had reds apart and the auto clutch works like a chainsaw clutch except unlike most chain saws the clutch is wet. This enables you to stop and not stal. This is designed to close around idel speed 1000-1400 rpms. The other is the high speed clutch?Now as far as I know the clutch plates which are in all atvs and motocycles(except belt drive) This clutch opens and closes at high speeds.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2006
    Halifax N.S Canada
    28
    Clutch
    Thanks for clearing that up for me............
    I live in Enfield. I just bought two Honda Big Red 200ES trikes. I have one going to NF for my father. I just finished making it roadworthy. My trike has a hard shifting problem. I have the clutch cover and the spacer in under it off to check the shift shaft mechanism.Both clutches are removed along with the shifter.Spent two days scraping off gaskets. So far everything looks OK but I will replace some springs on the shift shaft before reassembly. Barring that, if the problem comes back I may have to look at the shift forks and drum. I could use any technical support that I can get.
    Nov 2006
    Halifax N.S Canada
    28
    This is what it looks like at this point.
    Nov 2006
    Halifax N.S Canada
    28
    Oops......... pic didn't upload.
    Nov 2002
    1,836
    What is it doing? Some of those automatic bikes never really shifted right. Always clunking in 1 gear anyway lol. Or all the autos ive ridden and owned.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2002
    1,836
    If you still have any problems, look for any atc 200 for parts.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    illinois
    743
    go to whittier fun center and you can use the parts finder to see how they go together--
    Nov 2006
    Halifax N.S Canada
    28
    My Honda 200es is intermittently hard to shift and sometimes impossible to shift through the gears. It will happen a couple of times and then all of a sudden be ok for a while.When it happens I find that it is not gear specific as it is hard to shift into all gears. I have adjusted the clutch by backing of the slotted screw (CCW) untill I get resistance and then turning it in (CW) 1/4 turn. I am totally new to three wheelers. The shift lever feels sloppy but I don't know what a new one is like anyways. Its strange because this problem comes and goes. Its like something is stopping the shift lever. Need help on this.
    Nov 2006
    Halifax N.S Canada
    28
    The above was a cut and paste from another post just to explain the shifting problem.
    Nov 2002
    1,836
    Hmm Sucks to be you. Never had a problem shifting my reds. Just complety loosing 3rd gear thats all. Seems like the 3rd gear is a problem around here.
    hope you get things working again.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
