Thread: Is this a ATC or TRX bills silencer
    Minnesota
    784
    Got this silencer off ebay awhile ago, can hardly remember the auction, but I'm pretty sure it said trx250r silencer or I wouldnt' have bought it. If I hold the mounts tight to the mounting points on the frame right where the silencer goes from small pipe to large aluminum it hits the frame as seen in pic. If I slip the silencer all the way onto the pipe I need to pull it out a bit to get the mounting holes lined up, plus the bottom silencer mount is about an inch away from the frame, maybe it needs a factory hanger? This look similar to any of you guys's Bills silencers that have them on ATC's?
    The rear mounting hole doesn't mount in the grab bar, there is a frame mount behind the thing bolted to the silencer
    Attached Thumbnails Attached Thumbnails trx250rbillssilencer1.JPG   trx250rbillssilencer2.JPG   trx250rbillssilencer3.JPG
    Michigan
    1,220
    Almost all silencers use a factory hanger for both positions. The only one I know of that is a direct bolt on is ESR's silencer. I would bet thats a trx silencer seeing that its that close.
    Oregon
    2,471
    Nice .... Does it sound like gun shot's ?
    I say TRX ... i'll look at mine ...
    Aug 2006
    Arlington, Wa
    1,027
    use the factory hanger, you'll be tip top
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Minnesota
    784
    For the factory mount I'm missing, do I need a nut and bolt, or is the factory one supposed to have a welded nut to it?
