has anyone made, and or found something that works?
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
85' YTM 225DX (sweetie)
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
There is a guy in germany that makes some nice ones or you could still buy the oem one for like $10. What do you need one for? I have never seen or heard of a chain poping off a triz and breaking the case.
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
HA!!! I'm working with two sets of engine cases that have chain damage. The ones unweldable, but the other has been blasted and welded, I'm gonna lap em today and as soon as my stuff comes from Ronnie, assembly begins! HEHE!
I don't want to rely on the stock plastic, prolly gonna have a buddy machine me one if I can't find one stateside.Originally Posted by twgranger
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
Hey if you have one made, can you have one made for me also? I would pay you for it.
Original 85 TriZ owner![]()
Certified NASA welder PM me if you need any weldingI do extended swingarms and everything you can dream of
Three is Always better then four, unless its with women then four is better then three
the only problem ya have with that is the 85 motor has only one hole threded on the top and on the bottom is not threded. on my 86 motor i use a 250r saver that i cut and redrilled to fit The 86 motors have both holes threded. At least my 85 dont have the hole threded, can someone check there 85 to see maybe i got one that wasnt threded?
Nope you are correct, the 85 is not threaded. But the guy in germany made one kind of like stock... around the shifter. He wants 85$ last i checked and shipping is the same..... OUCH!!!! so if maggies boy is going to have one made maybe he should make a few and selll them![]()
That what i thought thanks!heres the 85 motor with the green boy raceing saver, and the 86 bottom end with my home made R saver
Can you guys simply thread that hole 6MMx1 and use it? If the hole is too big maybe you can use a helicoil to get the 6MM out of a hole too large for the tap alone..
Originally Posted by Dirtcrasher
I'm gonna check on that right now.
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
Originally Posted by maggiesboy
not even drilled out, I'll wait to get another case and try it.... I just got my bottom end put back together after a weld job.
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
i'm in the Work's of Making 25 of these thing's out of Billet ..MUCH Lighter and COOL !! But............ they won't be ready untill after Jan. 07 .. 25 bucs each
"07" DR650 Suzuki Dual Sport
Originally Posted by Yamahondaman
I'll take one! deposit?
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
NAAAAA .. i'm used to putting up my own cash for this stuff..espesially when i'm on the Clock !! makes it cheaper for "us" !!
i want 2 of those case savers,ronnie.I tell you what,just whatever you make for the z from here on out,count me in for at least 1 of them.Originally Posted by Yamahondaman
Proudly NOT a member of
"Team on the Teat"
