I've been reading this forum for a while and didn't find anything that matches my circumstance. I've been impressed with the technical knowledge I've seen and I hope someone can help me.
I have an '85 yt60 tri zinger and I have a number of questions about setting up the carb.
It hadn't run in a while so I took the carb off to check it out. It had quite a bit of junk in it and I got it all cleaned up. When I put it all back together it started on the first pull, but it doesn't seem to run right at all.
Firt off, if I get it to idle in start, when switched to run, the engine races and it takes off pretty fast, too fast for my little one.
If I get it setup so I can keep it running by feathering the throttle in start mode and then switchig to run, it seems to run ok, but its a little weak on the top end.
I noticed there is a bushing on the intake tube and a small gap on the carb in between the tightening screw and the body of the carb. Is there any special information I need to know about that?
I have tried turning the air screw in all the way, and unscrewing it all the way. It doesn't seem to make a difference. I blew through every hole in the carb with an air compressor and with carb cleaner, and both felt the air and saw the cleaner shoot through the other side.
I also ran torch cleaning wires through all the holes and reshot it with the carb cleaner and air.
Like I said It starts on the first pull, I just need some detailed instructions on seeting things up.
I appreciate it.
MikeC
