I just got this sled about a week ago, it is a 94 thundercat 900. It is only running on two cyliders and I need help figuring this out I'm not the the best mechanically with snowmobiles! I put new plugs in,cleaned carbs and new gas. I was told that the choke plungers stick on the older tripples sometimes so I cleaned it out and it does not seem to be sticking to me anyways. It also has spark. I t seems to be getting alot of gas maybe even too much seeing how the pulg is soaked after it has been started and I pull it from cylinder 1. Also I pulled all the plug wires off to change the plugs, Is there a certain order these must go back on from left to right when sitting on the seat your left hand side being cylinder #1? What thing can I look for and do to try to correct this problem myself? and which way should these plug wires go back on or doesn't it matter? Thanks![]()
