Results 1 to 15 of 24
Thread: why wont it start?
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    Question why wont it start?
    i have a 79 110 and its getting fuel and good spark but wont fire tried 3 diffrent carbs and nothing? i checked the timing and i think its good. i put the flywheel on the t and put the dot on the sprocket on the line and still nothing? does anyone have a pic of a 79 or 80 110 flywheel? i think mine is new or aftermarket cause it looks fairly new it also has 3 lines havent tried any of those yet. what is the o (i think) for? what would the 3rd non marked line be for? it ran before i touched it and put new rings in it should i check for compression? it seems to have it when i pull it over?
    Sep 2006
    S.E. LA
    700
    Have you checked the air filter? Is the carb flooding? When was the last time it was running?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Oct 2006
    iowa
    269
    it ran before i tore it apart kinda ruff but i tried diffrent carbs for 110s no air cleaner and the carb isnt running out of the overflow tubes
    NE Arkansas
    2,344
    Try a new spark plug. That has saved me sometimes from chasing other possible issues.
    My Rags
    Sep 2003
    El Paso Tx
    1,123
    How about the kill switch? I had to replace mine and off is on /on is off. Someone must have been drunk at the switch factory that day.
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Quote Originally Posted by TravEX
    Quote Originally Posted by 3 weelin geezer
    Both wrong, read his post he said he gets great spark, he cant get good spark with a bad plug, he cant get good sprak with a bad on/off switch. Im guessing since you said it worked *Edited**Edited* u took it apart its your timing. ALSO try to put some fuel into the cylender threw the plug hole and see if it even fires, if it does check for air leak, if not check your timing. Did you take the whole engine apart?
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Oct 2006
    iowa
    269
    took whole engine apart i sprayed fuel in cylendar and it will pop but not fire had it running for a little when i got done building the motor but now it wont start at all
    NE Arkansas
    2,344
    I've had spark before, but not enough to fire it up. A new spark plug is a simple thing to try. And, he said he already checked the timing.
    My Rags
    Sep 2006
    S.E. LA
    700
    Well if you aren't running it with an air box and filter I would at least try it with one on.
    '04 EZGO TXT
    Former trikes;
    Sep 2003
    El Paso Tx
    1,123
    How's the compression or did he already check that?
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Well he wasent sure on the timing, and a pop sounda like timing issues to me.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Oct 2006
    iowa
    269
    heres some pic of what i have. i read somewhere that the points are suppost to get a gap when it reaches the "o" but mine doesnt have a "o" they start to gap before they get to the t though is that right? it seems to have good compression i dont have a guage but i put my finger over it and felt pressure didnt blow my finger off though but it has more than another 110 motor i have laying around so look at the pic and let me know it also has a new ngk plug in it and it is a big bright spark
    Attached Thumbnails Attached Thumbnails IMG_1964_1_.jpg   IMG_1965_1_.jpg   IMG_1968_1_.jpg   IMG_1969_1_.jpg
    Oct 2006
    iowa
    269
    also whats the 2 other lines and the "f" for?
    Oct 2006
    iowa
    269
    i tried finding some stuff on the flywheel in my boook and shows nothing like what i have
    Apr 2006
    Crestview, Florida
    2,429
    pull the spark plug and stick a screwdriver in the hole to see if the pistons all the way up with the timing marks set.
