Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: why wont it start?
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    i looked down it and i think its all the way up i might check again? sould i pull the head and see what tdc is on the fly wheel?
    Oct 2006
    iowa
    269
    any other good ideas before the big holiday weekend?
    Sep 2003
    El Paso Tx
    1,123
    Here is a pic of my manual:
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    Oct 2006
    iowa
    269
    thanks ill have to look at it more i got it running i spun where the points are mounted a little at a time and it started still runs alittle ruff but its a start! when i put it in gear it wants to die on me but i might put the stock carb on it and see if it helps and ill adjust the points more what book is that? it doesnt show that in my haynes manual i have. aloso i think i need to adjust the timing chain might be too tight it whines alittle but not bad im so happy i got to ride it for the first time tonight!!! i wish i had more time to mess with it hopefully i have time inbetween the 7 christmas i have this weekend to work on it
    Oct 2006
    iowa
    269
    MERRY CHRISTMAS TO ALL and thanks for the help thats my best present yet!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Oct 2006
    iowa
    269
    ill be damed it is in my manual guess i was too excited to look close at it
    NE Arkansas
    2,344
    Congrats on getting it going!
    Merry CHRISTmas!
    My Rags
    central kansas
    27
    The "T" mark shows where top dead center is. The "F" mark shows where the plug actually fires. On internal combustion engines the spark actually fires ("F") a few degrees of rotation BEFORE the piston reaches top dead center ("T"). This is because it actually takes the fuel some time to burn, so the timing is set such that combustion starts before the piston it at the top. Your points should JUST open at the "F" mark NOT the "T" mark. Also, the "O" mark you are talking about is the one on the cam sprocket. It should point to the marker when the "T" mark is lined up with its pointer. Make sure that these marks line up correctly so your valve timing is right. (Piston at top dead center, both valves closed.) As you know, the ignition timing is affected by this as well since the points assembly is located and driven off of the camshaft. And by the way, I have seen plugs that will fire outside of the cylinder (hanging off of the plug wire) but won't fire under compression. It's harder for the spark to jump the air gap in that environment (under pressure). Your new plug is probably fine, but it's not that uncommon for a fuel fouled plug to fire outside the cylinder, but not in it. Hope this helps.
    Sep 2003
    El Paso Tx
    1,123
    Mine was dying on the trail and everything seemed all right. It turned out the spark plug had only around 5 k ohms and the new one around 27 k. I figgered it was burned up inside or something. It works now with the new plug. I guess that resistor or the spring inside were burned up and wouldn't make contact when the plug was upright.
