Results 1 to 9 of 9
Thread: will trx450r axle carrier fit 86 200x?
    Aug 2006
    NW Ohio
    1,043
    title says it let me know asap. im watching a couple of auctions going cheap.
    Jackson MI
    1,688
    I'm sure It will not fit. A TRX450 has a big axle like a 400EX or 250r. A 86-87 200x carrier Is alot narrower & has a smaller diameter axle. I just bought 2 off Ebay for a 86-87 200x.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Aug 2006
    NW Ohio
    1,043
    carrier
    the reason i ask is that mine is good but i figured that there are alot more axle options if i baught a 450r carrier and put it in my 86 extended swinger
    Jackson MI
    1,688
    It wont fit the swingarm either, a 450, 400ex, 250r, has a bigger & wider carrier than a 200x. If you cut the back section of a 85-86 250r swinger off & welded It to the 200x swingarm than you could do It.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jun 2003
    englishtown NJ
    2,676
    a 83/84 250r axle and carrier will fit in it. I have a 83/84r axle in my 200x right now. Also I am pretty sure the carrier will fit it(it is almost identical)
    Aug 2006
    NW Ohio
    1,043
    carrier
    what kind of mod work would be in order to get a 450r swinger to work on the 86 200x?
    Jun 2003
    englishtown NJ
    2,676
    alot, different legnth, different width, motor mount is built-into the swinger, you will need the rear brake and stuff. It is nearly impossible. also the 86 200x is a no-link, trx450r has a linkege that attaches to frame.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    if the 83-84 250R axles fits then I'm near certain that means an 83-85 200x one will also.
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    Couldnt you get a different I.D. bearing and run a bigger axle? Make the inner diameter hole in the bearing but same size outer and you should be able to install a bigger axle into the stock carrier using different I.D. (inner diameter) bearings?
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
