Has anyone done a swingarm ext on a TRIZ?I now its a dumb question because Im sure someone has, my question is do you do it to the original swingarm or did you make a new one? I have a spare swingarm but its HEAVY... so any ideas would help.
Original 85 TriZ owner![]()
Certified NASA welder PM me if you need any weldingI do extended swingarms and everything you can dream of
Three is Always better then four, unless its with women then four is better then three
Look for a thread with Bryan's 490z, he stretched his own waaaaay out. I think Yamahondaman (Ronnie) has one also. I'm sure someone with more info will chime in shortly.
Anyone????
well what do you want to know? anythings possible with a welder...
I took a stock tri z and mated it to a stock banshee and run a banshee rear end, this is for drags only, Ronnie make alum ones any size and hopefully hes gonna start my chromemoly +1-2 for my MX bike soon....![]()
Gents, I cut my swingarm and now I have a delema.... the tubing is 1 1/4 by 2 3/8 and nobody has that size tubing any ideas where I can get that size of tubing???? Or would you go with just smaller diameter and fit it into the original size??? HELP!!!! Please![]()
Any help with this would be appreciated![]()
what yolu will have to do is get tubing that is alittle bigger, then get it cut, so that it can be made the size to fit like this [ ] to this [] any welding shop should be able to cut some metal to make it work for you, aslo the best wayto do this is to pick up an extra swinger and cut and remove a piece from one for the other.
