Thread: 3 bolt hub into 4 bolt hub
    Harrison,Mi.
    38
    Question 3 bolt hub into 4 bolt hub
    I was wondering if I can put a 4 bolt hub on my 85' Yamaha Tri-Moto 225DRN? I would like put some Douglas wheels on the rear. Does anyone know if this is possible? If so, what hub's wiil work?
    Dec 2005
    Wisconsin
    1,141
    http://3wheelerworldforums.com/showthread.php?t=59152
    Thats the best answer I can give you.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    PA
    3,515
    your bike has 24 splines on the axle wich is the same as most hondas except 250r and 350x
    most yamahas are 24 spline too, so they will all work
    im running suzuki quad racer 250 5 lug hubs on my atc 110...most bikes are 24 spline
    WWW.HREATV.COM
    Fort Smith AR.
    44
    I used the Banshee/warrier rear hubs on mine. They fit perfect. I was under the impression the blaster hubs are different. I believe they have a different spline and/or bolt pattern. I also used the banchee 9" rear wheels.
    May 2005
    Dorset United Kingdom
    1,408
    If banshee fits, then Tri-z and blaster hubs will fit aswell.
    They do have a different bolt pattern though, 4/100
    Harrison,Mi.
    38
    Thanks for the great info! Now I know what to look for.
