I was wondering if I can put a 4 bolt hub on my 85' Yamaha Tri-Moto 225DRN? I would like put some Douglas wheels on the rear. Does anyone know if this is possible? If so, what hub's wiil work?
http://3wheelerworldforums.com/showthread.php?t=59152
Thats the best answer I can give you.
YTM-200, Wheeling machine!!!
1985 Honda 200x...
...Just a simple mild 200x
your bike has 24 splines on the axle wich is the same as most hondas except 250r and 350x
most yamahas are 24 spline too, so they will all work
im running suzuki quad racer 250 5 lug hubs on my atc 110...most bikes are 24 spline
WWW.HREATV.COM
I used the Banshee/warrier rear hubs on mine. They fit perfect. I was under the impression the blaster hubs are different. I believe they have a different spline and/or bolt pattern. I also used the banchee 9" rear wheels.
If banshee fits, then Tri-z and blaster hubs will fit aswell.
They do have a different bolt pattern though, 4/100
Thanks for the great info! Now I know what to look for.
