hey guys. i put the x cam in my trike now should i adjust the valves to 200s specs or to 200x specs? the x needs to be at 0.002 and the s is 0.003. is it normal for it to idle like a drag car? you know like it is going to stall out but it doenst.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
The stock Honda XR200 piston is 10.0:1 compression.
That XR cam looks good; it is also from the older XR which is supposed to have a slightly better cam then the newer ones. Of course that is providing the cam is the original. Apparently Honda switched to a slightly milder cam in the later XR motor and replaced the old part # with the newer style cam, this was to help emissions, or at least that is what I have heard. I was thinking of trying the aftermarket cam that is on ebay, I asked the seller and they said it is a stock XR grind but they never said what company makes it. Nice price though, here is the link (they list a new set about every week)...
http://cgi.ebay.com/ebaymotors/NEW-C...QQcmdZViewItem
I am not sure if there is a difference in the 110 and 125 cams, I do have a performance atc110/125 cam I would sell cheap. I will pm you about it.
84honda200s -
The 200x is the .003 and the 200s is .002. I would set it at the 200x (.003) specs. if it were my trike. The cams are different but the rockers are the same.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
thanks fox. a cam out of a 83 x shouldnt cause the valves to hit the piston shoud it?
thanks again
Nope.Originally Posted by 84honda200s
How does it compair to the stock cam in the 200s? Much of a difference? I have a friend who has a 200s and at some point we may put the spair 200x cam that I have in it.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
fox - that link is broken..
try to send it again if you can.
the 200x has better compression so it would be better to run it right? I dont see any listed on ebay for earlier years tho.. I will try to find an 82-83 wiseco for 2nd over on a 200x.
actually - the atc 200 wiseco has a 10.25: 1.. so that would work
quiet people seem intelligent
lets try it again... http://cgi.ebay.com/ebaymotors/NEW-C...QQcmdZViewItem
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Originally Posted by thefox
the x cam has more lift on it. its a decent diff. it was worth putting in i think. i cant tell u the diff because my s one was totaly shot.
I take it you are talking abuot the auction? I saw the name KCwrenches - dont know who it is.. let me know if it is someone from here and I wont try to snipe it.
