Results 1 to 8 of 8
Thread: ATC 110 questions
    70ATC90's Avatar
    70ATC90 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2006
    Minnesota
    235
    ATC 110 questions
    Just bought a 1980 ATC 110 from a guy who has had it for a while, he's tried and tried but can't get it running. The engine is complete, EVERYTHING is there. I did a compression test and it seems good. I took small engine repair in highschool but don't remember anything. What should i work on, tear apart or check on to get this thing going???
    1978 ATC 90
    2001 400EX
    Nov 2006
    Amishville
    119
    Assuming you've got spark, I'm guessing the carb needs a royal cleaning. Every trike I've got had a gummed carb with plugged jets when I got it.
    70ATC90's Avatar
    Nov 2006
    Minnesota
    235
    Yeah. I'm a quad guy so i've never been on something with a metal gas tank. Its got rust in it, is there any way to flush the rust out or should I just buy a plastic tank?
    1978 ATC 90
    2001 400EX
    70ATC90's Avatar
    Nov 2006
    Minnesota
    235
    1978 ATC 90
    2001 400EX
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Take the tank off, and the petcock off the tank, it has a screen on it, clean it, and flush the tank, i use water, let it dry or run some denatured alcohol through it, get an inline filter like one for a lawn mower for the fuel line. Fresh gas, clean the day lights out of the carb, pop in a new plug and give it a few pulls, see what happens. Good luck
    BTW New, and even used tanks can be costly, clean it up if you can, keeping the tank full if being stored for long periods will stop future rust.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    danteross77's Avatar
    danteross77 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2005
    Texas
    339
    If it is a 1980 model, that means it has points, I would definetly check those out first, and also check the timing of the spark(points)As for the gas tank go to a pool supply and buy some muratic acid.
    Feb 2006
    Central Florida
    1,090
    or phosphoric..
    phosphoric eats rust way better... but the tanks are hard to clean when you put chemicals in them.
    If it is not that rusty just put a small can of acetone in it and put about a pound of marbles in it and seal it off. Shake shake shake (shake some more) and pour
    or get a POR15 kit if it is really bad.
    If you go looking for phosphoric acid the easiest way you can get it is to buy a gallon of nickel safe ice machine cleaner.. really good for soaking nasty old parts.
    (will eat potmetal tho, - rinse good and dry good right after)
    quiet people seem intelligent
    Sep 2006
    S.E. LA
    700
    Or if you want to sell the tank let me know.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
