Results 1 to 15 of 18
Thread: plastic paint on metal?
    Aug 2006
    Texas
    997
    Would the Krylon Fusion plastic paint work on metal(the gas tank)? Asking because Im wanting everything to be the same shade, and am thinking that itd best achieved with the same paint from the same manufacturer. LMK~
    ps..does anyone have the part number for the Krylon Fusion red paint?
    84 Honda 200ES Big Red
    Im pretty shure it says on the can it will..Ill check a little later when i get back home.
    Apr 2006
    PA
    1,464
    Yes you can use it on metal, but if i was using Krylon I would give that a few coats of automotive clear coat, its alot stronger and wont peel off like regular spray paint.
    Aug 2006
    Texas
    997
    Cool deal. Ill pick up some clear too. Would you use clear on fenders? I dont want to have to wear sun glasses to look at it, but I dont want it to be totally dull either. Thanks for the quick responses, Im headed to the store now and will let you guys know what they have.
    Im bringing the gas tank for reference.
    Apr 2006
    PA
    1,464
    It might work on the fenders for a while, but i think it would eventually chip off. Its not ment to flex like krylon fusion is. If its a front fender i dont see why not. The duplicolor clear is a good choice too.
    Aug 2006
    Texas
    997
    Yeah, I decided against clear. One determining factor...They didnt have it in Fusion. :P
    I got Krylon Fusion 2328 Red Pepper/Safety Red
    Even though it was the only red shade they had, it appears to be a near perfect match when holding the cap against the gas tank. I will see when I spray the fenders. The bottom is getting done first, then let dry to see if it dries to the caps color. Doesnt spray paint usually dry a little lighter than the cap anyway? We will see!
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    those caps lie more than politicians! lol...
    Aug 2006
    Texas
    997
    I got the bottom sprayed. It started to get cold, so Ill just do the top tomarrow or whenever it warms up.
    It was really orangish looking at first which made me think I just wasted 10 bucks on 2 cans of paint! Well, as it dried, the redder it got. Now, fuly cured, it looks like a near match! The only problem(which isnt really a problem) is that its duller than Id hoped. Oh well, its shinier than after I tried the 'plastic restoration' with sandpaper. They looked like pure hello. Now.....not so bad!
    FWIW, the paint dried looks exactally the same as the cap. So, I guess this one wasnt made by a politician?
    Jun 2006
    Orrville,Ohio
    171
    Sure you can use the plastic paint for metal, but it's not going to last.
    Get a little gas on it and it's coming off.
    If you want a paint job that is going to last awhile on plastic.
    A base coat/clear coat is the way to go. The paint and clear are very flexable.
    You need a good clean surface, ad. promoter, primer for plastic and base/clear coat. Should last years unless you trash it.
    tyman's Avatar
    Jul 2006
    458
    haha.. your lucky... i've had bad luck with s..... usually the colors are way off....
    Aug 2006
    Texas
    997
    I got the top done and everything put back together. Its not perfect, but is very satisfactory. Up close, you can still see scratches(I filled in with putty) and whatnot, but hardly. Its a 2 footer. Ill try to get some pics up soon.
    Aug 2006
    Texas
    997
    I havent painted the gas tank yet, but hopefully it wont look too different from the fenders.
    Sep 2005
    FL
    855
    That looks nice. Did you use a primer or sand it down first? That thing will be a lot nicer than when I saw it.
    I picked up a can of a Fusion latex paint to try on some fenders. I don't know how well it will hold up, I figured the latex should give it some flex. I did not look to bad. I just tried it on a old useless set of fenders with no sanding or priming.
    Aug 2006
    Texas
    997
    I wet sanded it with (I think) it was 2000 grit.
    Dec 2006
    ofallon mo
    103
    dude is that bike in *Edited**Edited* living room???????????????
    1985 honda 350x
