Results 1 to 15 of 19
Thread: How hot should an engine run???
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    i was just out riding my 86 200x... i just put a new uni filter on it, new sprockets, and new bearings front and rear... after i was done riding, i couldn't touch the side cases or the fill plug it was so hot, after getting a rag to pull out the oil fill plug, the oil was so thin, it literally ran off the stick... i used castrol black cap (i think its 10w40) and about 2 or 3 oz. of lucas oil treatment, which is super thick... i only rode it for ~30 minutes... so how hot should it be????
    Nov 2006
    Tulare, California
    719
    I don't think any engine will be toutchable after 30 mins of riding. I find that 20/50 is a great oil for all riding conditions.
    the lucas might have plugged something up that stuff is thick and should only be put in a hot motor. try changing the oil again after its warm. It should not be so hot that you cant touch the case or filler plug.
    Randolph NY
    597
    It should be warm yes, but not hot to the point where you cant touch the sidecases or the plug. Is your oil synthetic?
    tyman's Avatar
    Jul 2006
    458
    nope just regular oil.... and yeah it was really hot... it ran fine though... i was thinking about that new filter.. it draws alot more than the old 125m filter i had stuffed in it... could it be that the mixture is way to lean??? and its getting very hot?
    diggerzmound is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2004
    Nebraska
    187
    Air Cooled engines can run in excess of 300 degrees. Keeping it moving is the best bet, idling can cause overheating.
    My Ride - 2001 Raptor, HotRods 720 Stroker.
    94' Banshee- Bing Bing Bing
    85 Tri-Z, 6 Speed, Power Valved, Boyesen Reeds, DG Pipe.
    Kids - Lil' Yamahas
    Summer rides - 1100 Wave Raider, JS550, 06' V-Max
    Winter toy - 95' V-max4
    Nov 2006
    Oshawa, ON
    26
    Quote Originally Posted by tyman
    Thats what happened to me when I changed from the stock air filter to a UNI on my 185S. I'ed try doing a plug chop test, because if its that hot your probobly too lean.
    Jul 2006
    also did you rejet for the UNI filter, a lean condition will overheat your motor as well
    tyman's Avatar
    Jul 2006
    458
    i'm going to do a plug chop tomorrow, and then raise the needle clip.. i guess that makes it richer right???? hopefully that'll solve it, cause my dad refuses to let me buy jets... he says they are "a pain in the @$$" .... but then again, since when do i actually listen to what i'm told???? anyone know what kind of jets a stock keihin 200x carb takes??? their are so many different series... and how do you tell what size the one in it is????? thanks
    Dec 2006
    red neck land mn
    22
    a lot of people put these on to tell if there runing to hot http://www.cvproducts.com/cv/product...09&brandID=197
    bandndesigns.com
    Jul 2006
    boonis those work well on a liquid cooled motor but surface temps on air cooled motors can be much more than that, tyman, do you have an airbox lid on? that will richin it back up a bit, raising the needle will help and screwing IN the air/mix screw will help, but to help on top end throuttle you will need a bigger main jet.
    Jun 2003
    englishtown NJ
    2,676
    I have only seen kehien jets and mukuni jets. I used rugular kehien jets in my 200x carb. I think I had a 125.
    Jun 2003
    englishtown NJ
    2,676
    correct me if I'm wrong, but lowering the needle clip riches it and raising the needle clip leans it.
    Jul 2006
    ooops I read it wrong my bad, yea if you raise the needle clip that leans out and if you lower it richens it
    Sep 2006
    Northwest Indiana
    1,893
    My liquid 85 t3 runs at 155 according to my ESR billet gauge. I know you are not liquid, but, this is just for reference for other liquids out there. I can also tell you that in the summer after a good beatin when its humid, the clutch cover feels a lot hotter than that to me. Remember, as outside temperature rises jetting becomes richer and vise versa. Bump up the main a bit when cold and it may cool it down a bit. Four strokes are much more forgiving than our two strokes in the cold so dive in and show dad you what you've learned.
