Thread: which 350x bearing carrier to go with?
    Dec 2002
    Janesville,WI
    573
    As far as i know,lonestar,boss,magnum and rad make a bearing carrier for the 350x.The lonestar one you have to use a 300ex sprocket and bolts for it to work(clearance i was told).I just bought a durablue hd axle and was wondering if i went with the lonestar,would the axle have to be a 300ex too,or would it bolt right up?Can i go with one of the other ones where i don't have to change the sprocket?I just bought new f/r sidewinder sprockets for it,so the less hassles the better.Here's a pic of my 350x before i tore it down to be completely redone.
    Aug 2002
    332
    Hey dude, nice X! I recently installed a DuraBlue +4 HD axle in my 350X along with a tapered bearing carrier from Magnum. I got really good deal on it from www.dirt-deals.com. They are something like $259, and since the dual row carrier ($179) which I initially ordered was on backorder for a month, the guys sold me a tapered one instead for $179. The tapered carrier features an external grease zerk for quick lubing, and the bearings are supposed to last 3 times as long as a regular bearing. Also, all of the parts on the carrier including the housing itself are lifetime guaranteed, so if anything ever cracks, send it back for a new one. Here is a pick of my setup. Hope this helps.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    Aug 2002
    332
    I failed to mention that all of the stock parts work with the Magnum unit that I bought, so you don't need any special sprockets or other parts. Bolts right in.
    Joel Morris
    1985 ATC70
    Dec 2002
    Janesville,WI
    573
    Thanks joel.I was looking at the boss one on ebay from inland atv for $150.Was wondering how good they are.Nice trike my friend!What you have red will be black on mine,plastic too.Waiting for the powdercoating to get done. I know tapered bearing carriers cost more,but what makes them better?
    Aug 2002
    332
    Think of it this way: a standard bearing is capable of holding your axle as if you were holding a stick with the tips of your first finger and your thumb in both hands. A tapered bearing would be analogous to you holding the same stick except with your whole palm and fingers wrapped around them.
    A standard bearing can not handle more than about 600 lbs of side load, like if you slid around a hard corner, or even into a tree. A tapered bearing can handle about 6000 lbs of side load (I'm not kidding) from the same impact. The reason is that the tapered design takes a side load and converts a portion of that load into a vertical load which the carrier would absorb. The hearings ride on a surface that is somewhat perpendicular to a side load, therefore, the load is actually on the carrier instead. The carrier is capable of handling a huge amount of loading, so it ends up being about 10 times stronger than a standard set of bearings.
    Sorry for the long explanation, but I wanted to get some gears spinning for anyone who is interested.
    Keep in mind that having an external grease zerk is like getting a $1000 bill for your birthday, nice and handy.
    Joel Morris
    1985 ATC70
