Thread: 84 200x in need of rejetting?
    Mar 2004
    I have a stock 84 200x and i just put on a performance cobra exhaust and someone told me i should rejet. It seems to run alright which jet would i need to change hsp or lsp, and what should i change it to? Im not even sure what my carb has for stock jetting. any help would be appreciated.
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    you might not have to rejet... just do a plugchop..... if its lean, then you should probably up your main..... but sometimes you don't have to rejet...
    Jul 2006
    galway ny.
    534
    take the bowl off and take the main jet out. see what it says on it. if your x is running good why bother? but if you want to mess with things buy some jets from dennis kirk and play around some. i put a 28mm from a xr 200 dirt bike on my x with a bigger intake and cylinder and piston with a full dg pipe , it works for me.
    85 tecate 86lt250r
    85atc 200x
    Mar 2004
    Now that i think about it at high speed it does start cutting out a little bit. Like its starving for fuel.
    Jul 2006
    galway ny.
    534
    put a bigger main in''
    85 tecate 86lt250r
    85atc 200x
    Please, please, please jet the thing up and enjoy the extra power provided through the better breathing exhaust. And, remove the airox lid and cut some big holes in it - but only run it when your gonna have a bad water and mud day.
    I have never changed an exhaust and "not had to rejet" - nope, you don't "HAVE" to but why the hell wouldn't you? Did you just want a pretty pipe or were you looking for some gains??
    My 200X has some 250SX jets in it and a 250SX main that got drilled out a few times with a drill bit until I got it right. Do the dam plug chops blah blah blah but I find 2 strokes read better than a 4 stroke. I just ride it until it feels right, you obviously can feel the lean out condition in the WOT position with your current jetting.
