hello
I recently got my Yamaha ytm 200L running and I got it all together today and when you give it about 1/8th throttle it will move alright but if you give it anymore throttle then that the clutches slip (I think) and it wont moves. Would this be the primary or secondary clutch or just the adjuster not set correctly on the clutch cover.
What should the clutch adjustment be set to?
when you take the nut off the adjustor and grab onto the threads the nut came off with your hands should you be able to pull the bolt/threads back about a quarter of an inch because mine will come back and im starting to think I have a sour adjuster.
Any help is greatly appreciated
