Results 1 to 15 of 16
Thread: xr 350
    p26575r16's Avatar
    p26575r16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Reno NV
    252
    xr 350
    does anyone know if there is a difference between a xr350, and a atc350x engine?
    '86 350x
    '05 sportsman 500 (the couch)
    PA
    3,515
    yes
    the 350xr motor sucks compared to the 350x
    WWW.HREATV.COM
    St Helens, OR
    611
    i have/had both...
    i thought the xr350r motor made more power. hence the people wanting to swap XR cams into their 350x
    PA
    3,515
    you might be right stock vs stock
    i read some ware that when building a race motor the 350x has more potential then even the xr500 head on a 350x
    WWW.HREATV.COM
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Got any pics of the motor?
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    I do not have any pics of the xr engine edog, but they look very similar with the exception of the heads. The xr head has 4 letters on it that the x engine does not have. I did find some pics of the xr engine by doing a yahoo image search.
    '86 350x
    St Helens, OR
    611
    Nov 2001
    B.C.
    933
    The XR you speak of is the RFVC engine. A very stout radial valved engine. As far as the head, totally different from the ATC engine and nothing will interchange.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Southeast KS
    42
    I know this is an old thread, but it got me wondering if an XR 350 motor would swap onto one of the 200 ATC frames? Would it be worth the hassle & how much performance could I wring out of it?
    Williamstown PA
    5,826
    it wont, its way to large and they had dual carbs so there is no room. a 185 motor will slip in no prob.
    Southeast KS
    42
    Easy enough answer, thanks! One more question though. Why would you want to put a smaller motor in? Did the 185 have more power? Not that I own an ATC yet, just puttin' some new knowledge in the old attic.
    Williamstown PA
    5,826
    185 motor made more hp then then 200 motor form what i remeber. the 200 has 25 tires and was larger, the 185 was smaller with 22" tires, all in all its the same motor with 15cc less on top end. i had a 185 motor in my autox that was bored to about 215 from what i figured out with all the overbores.
    Feb 2006
    Texas
    738
    Are we talking about a 200X? Not that is impossible, but, I doubt very much the 185 had 18 h.p. (stock) The latter 200x had 19. That's as much h.p. as the Honda 300EX engine, without the weight.
    I hope you guys were talking about a 200X motor. If not, well, sorry...
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Williamstown PA
    5,826
    talking about atc200 motors and atc185 motors, not 200x motors.
    Southeast KS
    42
    Wow! So I take it that the 185 either had more compression, a bigger cam, a better head, or a combination of the three to get more power from less cc right?
    LOL. I'm taking this thread off topic now, but are there any charts or info on all of the ATC specs like power, weight, & dimensions? I've seen a few advertisements & such, but no specs. Surely something's out there if the info is available for Yamaha 3 wheelers. I'm still looking around here to find out as much info as possible, but there's so many variations in just the 200cc trikes, not to mention the 70, 90, 110, 125, 185, 250, & 350 stuff!
