What exactly is a turbo crank? Is it just a lightened crank? would this be a good add on to a 310r? Who can do it?....Ronnie?
Kevin
Kevin
- Chick McGee
-1985 250sx
- 1986 atc310R drag bike
- 1981 110 chopper.
- 1985/6 350x
- 2-84 atc250r's and 1 83
- 2002 trx400ex
- 1985 atc 250r
-1985 atc70 WTB PARTS
- 1985 tecate
Its Veins cut in the crank....some say it works......most dont.....ronnies version is a little diffrent, has like a Machined Rough surface to it.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
it worked for me on my old 89 q-racer
WWW.HREATV.COM
well does it lighten the crank or what? it seems like a couple small scratches in the crank wouldnt do much good for anything.
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
All of the "turbo" cranks I've ever seen had a knurled finish on the outside of the flywieght's surface. It's supposed to create a turbulance or "turbo" effect on the intake charge in the lower end. Does it work ?? I don't know. Doesn't make the crank any lighter.
"You should never smoke in pajamas..
You might start a fire and burn your face..
Maybe you should return to Manaugua..
You could go un-noticed in such a place"
FZ
Ass,gas or grass....nobody rides for free!
Ride free,Brotha. See you in Heaven.
my turboed crank and nathens crank
does this really work, looks like a lot of work for little gain... with what the increase for this do you know?
Original 85 TriZ owner![]()
Certified NASA welder PM me if you need any weldingI do extended swingarms and everything you can dream of
Three is Always better then four, unless its with women then four is better then three
Nathans crank look like it might seriously work.Do you have any information on it ?ThanksOriginally Posted by bryan raffa
so now for the ultimate question. Is it worth messing with? and how much does ronnie charge to do one?
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
you need to contact him he does the one on the left that knerled(sp)
It mixes the the gas and air thats in the case for a better burn(turbo effect), thus creating more hp, is the theory behind it.
well the bike already has to run 110 octane in it, think the turbo crank would give it more oomph or would it be a waste for this bike? The bike has an esr310 kit, some huge carb (not sure what it is), a +12 swinger, and an FTZ out of frame drag pipe.
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
I think that other one is actually the crank thats in Ronnies Z.
it for shure is not going to hurt it at all!!!
its alot of work for little increase dont you think? unless you wnat to do it for the fun if it....
when ya build a drag bike every little bit helps, Just like removeing weight every little bit helps!!
