Results 1 to 15 of 24
Thread: Turbo crank?
    Jan 2005
    Jones, Michigan
    1,821
    Turbo crank?
    What exactly is a turbo crank? Is it just a lightened crank? would this be a good add on to a 310r? Who can do it?....Ronnie?
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Aug 2004
    Ab Canada
    4,368
    Its Veins cut in the crank....some say it works......most dont.....ronnies version is a little diffrent, has like a Machined Rough surface to it.
    1985 Tri-Z-
    PA
    3,515
    it worked for me on my old 89 q-racer
    WWW.HREATV.COM
    Jan 2005
    Jones, Michigan
    1,821
    well does it lighten the crank or what? it seems like a couple small scratches in the crank wouldnt do much good for anything.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    All of the "turbo" cranks I've ever seen had a knurled finish on the outside of the flywieght's surface. It's supposed to create a turbulance or "turbo" effect on the intake charge in the lower end. Does it work ?? I don't know. Doesn't make the crank any lighter.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    my turboed crank and nathens crank
    mnnmaz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2006
    Arizona (USA)
    222
    does this really work, looks like a lot of work for little gain... with what the increase for this do you know?
    Original 85 TriZ owner
    Certified NASA welder PM me if you need any welding I do extended swingarms and everything you can dream of
    Three is Always better then four, unless its with women then four is better then three
    Apr 2006
    oakridge oregon
    124
    Quote Originally Posted by bryan raffa
    Nathans crank look like it might seriously work.Do you have any information on it ?Thanks
    Jan 2005
    Jones, Michigan
    1,821
    so now for the ultimate question. Is it worth messing with? and how much does ronnie charge to do one?
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    you need to contact him he does the one on the left that knerled(sp)
    It mixes the the gas and air thats in the case for a better burn(turbo effect), thus creating more hp, is the theory behind it.
    Jan 2005
    Jones, Michigan
    1,821
    well the bike already has to run 110 octane in it, think the turbo crank would give it more oomph or would it be a waste for this bike? The bike has an esr310 kit, some huge carb (not sure what it is), a +12 swinger, and an FTZ out of frame drag pipe.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I think that other one is actually the crank thats in Ronnies Z.
    it for shure is not going to hurt it at all!!!
    Sep 2006
    Arizona (USA)
    222
    its alot of work for little increase dont you think? unless you wnat to do it for the fun if it....
    when ya build a drag bike every little bit helps, Just like removeing weight every little bit helps!!
