i have been working on a yt175. It cranks up first pull almost everytime. If it doesnt on the first pull then it want. you have to let it sit for a few then it will crank right up. While running in nuetral you can rev it all the way without a single miss. If you put it into first you usaully only have half throttle, in second a 1/4 throttle and so on. Then sometimes it will just stall. You will be putting along and then nothing. No misses or anything. I have cleaned the carb but nothing has changed. I was hinking that it might be the fuel pump. if anyone has experienced this let me know.
