Results 1 to 8 of 8
Thread: Basic Spark Plug Question
    Aug 2005
    Portland Or
    412
    I was perusing the Honda 250r manual today and noticed that there are two recommended plugs: BR8ES and BR9ES. The 8ES is recommended for cold weather. What is the difference between these two plugs? And I use only a BR8ES, if I were to use I 9ES what changes would I see? Thanks.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Pennsylvannia
    1,147
    I think that the 9ES has a hotter spark. Just stick with the 8.
    May 2005
    Dorset United Kingdom
    1,408
    No cigar nouse heh
    The number refers to the heat rating of the plug, this is the amount of heat the plug will conduct away using the ceramic nose. The cooler rated plug (higher number) will have a longer ceramic nose. The hotter plug (lower number) will have a shorter ceramic nose, sometime on really hot plugs recessed down into the plug.
    A cooler plug may mean that the ceramic conducts too much heat away and there is a build up of deposits as they are not burnt off, this leads to fouling, Too hot a plug will not foul, but may not conduct enough heat away and will lead to pre detonation!.
    You want the coolest plug you can run without fouling, this also depends on how you ride
    Columbiaville, MI.
    1,508
    That's true sloth But... with the NGK plugs ,other brands such as Champion and what not ,are hotter plugs as the numbers go up,just to clarify !!
    MDR Racing
    LONG LIVE SANCHEZ RACING
    mnnmaz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2006
    Arizona (USA)
    222
    off the subject but what is a powervalved TriZ? I use both and see no difference but I know the R is for resistor but who cares?
    Original 85 TriZ owner
    Certified NASA welder PM me if you need any welding I do extended swingarms and everything you can dream of
    Three is Always better then four, unless its with women then four is better then three
    Sandpuppi101 is correct. For domestic makers, the higher the number the hotter the plug. This is just the opposite for Japanese makers like NGK and Denso (ie the higher the number the colder the plug). Unless you have made significant changes to the engine, I would say you should stay with the stock plug.
    May 2005
    1,408
    Yup, I should have said that was talking about NGK's thanks guys.
    Aug 2005
    Portland Or
    412
    Thats what I needed to know. Thanks everyone.
