Results 1 to 15 of 21
Thread: Any ideas on how to buff a front tire with some decent precision?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Heres the predicament guys, Our flat track league and tracks down here will not allow knobbie tires. And you cannot get a flat track tire in an 11inch rim. If you've got a bald knobbie tire you can probably pass, but if you don't your SOL. I'm trying to come up with some cheap, fairly precise way to either buff, burn or slice the tread off where its even for the most part. The idea I've been kicking around is make a stand for the front wheel and tire to sit on, and a piece of steel or stainless wire with a current running through it to make it hot (Like a hot water heating element) where you can rotate the tire and the wire will "cut" through the tread. I don't know jack about electrical systems though so I'm not even sure how feasible something like that would be. Input/Ideas?
    Maryland
    3,077
    Sounds like as good an idea as any! Go for it!
    Aug 2005
    HI
    1,575
    Aren't you running a 10" tire? I know they make sand tires that are completely buffed. You could look into that.
    Rest in peace Rex Carlson
    Live Oak, FL
    15,069
    Yeah I am, I'm covered. But no one else has a 10inch front wheel, everyone is running 11s. I know skat track does make buffed 11inch tires but they are super super thin and I personally just don't like the idea of that on a flat track.
    tire groover!!! cut the knobs off then use a grinder stinks like a mofo!!!!
    Michigan
    1,220
    I've got a tire groover if you need it, our season doesn't start for a few more months.
    What about grinding the knobs off? I use a grinder on my hoosiers after every other race to take off the glaze but you could put some 20-40 grit on and take them down pretty quick.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Billy, let me see if I still have the one tire at the shop. If I still got it, you can have it for actual shipping cost. I will know for sure Monday night. As far as a shaving a tire goes. We bought a machine years ago that had a tire on it that was sanded down for flat tracking. The guy we got the machine from said he used a belt sander with a course belt. He had mounted the sander in a wooden fixture so the sander would sand from side to side. He had it at a slight angle so the tire would rotate slowly. He would sand off the tread taking just a slight amount at a time until he got it down to where he wanted it. He was doing some quad tires ( for someone else ) while we were there. It was quite the set up. I wonder if he still has the jig. hmmmmm
    Now if you want to use the cutting method, then I would probably use a heating element out of a clothes dryer ( heavier element ), a hair dryer ( lighter element ), a electric heater, electric stove, ect. Take one of the elements and straighten it out ( should work by pulling it tight ). Then use it in a fixture to trim the knobs off. It may or may not work, but finding used stuff to do this would be easy and cheap.
    Howdy
    Columbiaville, MI.
    1,508
    Grinding is gonna suck,Like they are saying a tire Groover will do the best especially with the soft rubber,If you need one I can ship the one we use to do our pullers with,and you can use it ,it's bad Arse!!!
    MDR Racing
    LONG LIVE SANCHEZ RACING
    Mar 2004
    North Central Ohio!!
    2,712
    Personally I think if I build a flat track bike I like the idea of a 12" Tri-Z hub and wheel with a nice turf tire. If you really want a trick front tire check this one.
    http://www.minimania.com/web/AddedFr.../InvDetail.cfm
    But the other real good option is the douglas 10" front wheel with an Achieva Racer on front.
    Jackson MI
    1,688
    Billy, Get a small Air hacksaw & cut the knobs off. Then talk to a truck tire guy & get a buffer attachment for your die grinder & buff the crap out of It. Might take a long time, but It'll be cheap. The buffer attachment I'm talkin about Is what you would use to buff the Inside of a tire when patching It.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    I've cut tires with an electric planer. I've also used a 8" milwaukee grinder with a circular saw blade in it, that is kinda dangerous though.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Goulais River, Ontario, Canada
    90
    Whats that a 500R? Burn em off
    Thanks alot, Billy Bob (Bob Menard)
    E-bay- bobby-menard
    e-mail - das_boobie@hotmail.com
    1982 Honda 250R - PROJECT
    2 - 1984 Honda Big Red 200es
    1984 Honda 200s
    1985 Honda Big Red 250es
    1987 GMC C-1500 - Modded (Project Weekend Truck)
    1997 Polaris Indy XLT 600
    2004 Yamaha V-Max 1200
    2005 Ford F-150 Lariat
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    Could hook up a piece of MIG welding wire, hook both ends to 2 big car batteries. Let it heat up and then cut the nobs on with it. Or you could hook the wire to the ground clamp, and the other in the stinger on a stick welder. Crank the amps way up and slice right through it. We use that method when cutting HUGE chunks of stirofoam. Should work great for rubber to.
    1983 250r
    1986 200x
    1985 250sx
    Live Oak, FL
    15,069
    I was wondering if hooking the wire up to an arc welder like that would work. I think I might try that. Thanks for the tips guys!
    Aug 2005
    HI
    1,575
    stick the wheel/tire on the back of one of your trikes and do a burnout with it. Then buff the sides off.
