hey guys when you order progressive springs like from denniskirk do they come in sets of 2? I know its a dumb question but i cant find it anywhere. Also wheres the cheapest place for these springs? denniskirk has them for 75.99
Kevin
Kevin
- Chick McGee
-1985 250sx
- 1986 atc310R drag bike
- 1981 110 chopper.
- 1985/6 350x
- 2-84 atc250r's and 1 83
- 2002 trx400ex
- 1985 atc 250r
-1985 atc70 WTB PARTS
- 1985 tecate
also do the "dust seals" in the forks normally need replaced or should i just buy the oil seals and call it good? and also should i go stock with the seals or would parts unlimited be a good choice? Ive never had to rebuild shocks so im lost.
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
I've got an even dumber question: what is the advantage to running progressive springs? I have not ever heard of them until I joined 3WW.
'86 350x
'05 sportsman 500 (the couch)
Originally Posted by p26575r16
Just found a thread on progressive springs. Imagine that, they do what they are called. I think I am going to order some also so my question is now your original one. Are they sold seperatly?
'86 350x
I think these fit 85-86 250R's but I'm not 100% positive.
The Progressive springs come in sets of 2. Dennis Kirk is one of the cheaper places to get them.
Normally the dust seals can be re-used. If you get aftermarket oil seals, most don't even come with dust seals. If you order the Honda seals though, they all come together.
The thing is though, usually if your current seals are leaking it's because your bushings are shot. My suggestion (after learning this myself) is to go with the Honda seals and new bushings. All these parts are cheap and once they're replaced you'll get another 20 years of leak free use!
Look here, you have to find the part number off of DK and then find it here. They seem cheaper though.
http://www.mawonline.com/progress.htm#Fork%20springs
FYI Kevin, run something on top of the dust seals. I thought they were going to be fine, but I still think that was my problem was dirt getting in there and buggering up my seal. Just something to go overtop, boots, covers......
RPFLU member and co-owner.
Hardtails is all we do.
#NOLINK
#MAKEHARDTAILSGREATAGAIN
#SUSPENDTHIS
Originally Posted by Kintore
10-4 on the covers... the neoprene wraps you see in Derrick's pic is just about the best way to go. In my opinion.![]()
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
85' YTM 225DX (sweetie)
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
so I cant figure out how to interprate the page.... which set is for the 85 TriZ???? I would like to purchase a pair but.... I have no idea how or which ones to buy! help![]()
Original 85 TriZ owner![]()
Certified NASA welder PM me if you need any weldingI do extended swingarms and everything you can dream of
Three is Always better then four, unless its with women then four is better then three
Originally Posted by Derrick Adams
hey derrick my seals arent even leaking that i know of. I am rebuilding this whole bike to "like new" though so itd be stupid to not change the seals/bushings and springs in the forks. I just wasnt sure on the seals and what brand i should eet. I am planning on getting bushings from honda which are only like $7 each i think.i think i'll get black fork boots for it too.
And dammit, those springs will work in the atc250r. its progressive spring number 111127
Kevin
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
Originally Posted by mnnmaz
here ya go http://denniskirk.com/jsp/product_ca...1041#altImages
- Chick McGee
-1985 250sx
- 1981 110 chopper.
- 1985/6 350x
- 2002 trx400ex
- 1985 atc 250r
- 1985 tecate
As far as the fork boots go, look around. I found a set of black ones for 4wd trucks that are identical to the ones on ebay. The ones on ebay are about 20 and I found them for 8 bucks. Check some auto parts stores in the truck section. You'll save some cash.
