Results 61 to 75 of 85
Thread: 83 250r Locked up PICS--*FIXED!
  1. #61
    Feb 2006
    Mass
    37
    Quote Originally Posted by sykolincoln
    you just got to push the wrist pin out, sometimes it can be a pain, but it will come out, but whatever you do dont use a to push it out!!!
    hahahah... I laughed my ass off after you said that, and then I instantly read in your profile "if it doesn't fit, use a , if that doesn't work, get a bigger !!" LOL
  2. #62
    Jul 2006
    lmfao!!! I should put a side note in "ecept when taking a wrist pin out" lol!!!
  3. #63
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    im currently installing the piston. should the arrow on the piston point towards the carburator??? thanks a lot
    1983 250r
    1986 200x
    1985 250sx
  4. #64
    Jul 2006
    negative!!!! arrow---> to exhaust!!!!!
  5. #65
    Jul 2006
  6. #66
    Jul 2006
    Tennessee
    416
    thanks a lot syko... putting clips in her now. gettin excited
    1983 250r
    1986 200x
    1985 250sx
  7. #67
    Dec 2006
    central in.
    83 250r locked up
    jet up main 2sizes and maybe raise needle in carb 1 notch by lowering c-clip also be sure to always warm up an air fooler very well to advoid a cold seizeure.
  8. #68
    Jul 2006
    Tennessee
    416
    I don't really want to mess with the jets at all, since it was running flawless until this happened. I don't think it was my carb that caused it either, or I think it would've happened sooner. What are some different precautions to take when braking it in? In the service manuel It says to replace the plug with a BR8ES, but that is hotter than a BR9ES....Shall I go with the 9?
    1983 250r
    1986 200x
    1985 250sx
  9. #69
    Dec 2006
    W. PA
    463
    just wanted to add that the ends of the rings never go over the exhaust port, never know when you might get some oddball piston that is marked differently.
    1984 250r
    heap of 200x
    POS motorcraft?
    Quote Originally Posted by JAGSFOLIFE
    THOSE F^@&ERS ARE DEATH TRAPS, BUT SO BAD @$$...
    Quote Originally Posted by yamaha gp
    trikes... DANGEROUS MOTHER F***S. BUDDY LOST HALF HIS SPLEEN AND A LIVER BECAUSE OF ONE OF THEN. HAHAH
    Quote Originally Posted by smackdab
    We decided those cute little 90 and 110 Honda 3 wheelers were what we all needed. Although our experience with those little SOB's is a story for another day, I will tell you that the Caro Community Hospital got new waiting room furniture due to those cute little devils.
  10. #70
    Jul 2006
    well the rings on a 2 stroke hav elocater pins in them to keep them from rotating around and catching a port, also do a couple heat cycles let it run for a few mins then cool completly do this a few times then drive it a few times, never going over 3/4 throttle, and let cool completely, maybe have alittle extra oil in the gas for break in, also jst run the b8es plug it will be fine, you should be ok.
  11. #71
    Aug 2006
    Arlington, Wa
    1,027
    Quote Originally Posted by smyers33
    Here is a pic of the blade looking thing, for some reason I thought it had something to do with the reeds.
    That really looks like a "power now" insert that failed. I've had customers return them due to a failure..."coming apart"
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
  12. #72
    Jul 2006
    Tennessee
    416
    IT'S RUNNNING!!!! I just got to set the idle, and then I'll start doing some heat cycles. Thank you everyone for all your help through this. I had not one trouble at all doing it and I am amazed at how easy it its. Also I'm amazed at how hard it is to kick now! I LOVE IT!!!!! How many hours do ya'll suppose it'll be before I can go all out? Here is a vid of the first start up, on the coldest day of the damn year!!! LOL I LOVE IT!!!
    1983 250r
    1986 200x
    1985 250sx
  13. #73
    Oregon
    2,471
    Question
    Sounds Good -
    Is the Seller Going to pay for Any thing ?
  14. #74
    Jul 2006
    Tennessee
    416
    I decided not to even deal with him... I know some of you would, but I decided to let it go...Even though I probably should have made him. I don't know if that is right or not, but I'm happy since I've got it running!
    1983 250r
    1986 200x
    1985 250sx
  15. #75
    Jul 2006
    yea just do some heat cycles to it, try not to let it just sit and idle blip the throttle every now and then, do that about 4-5 times then go ride a few times not staying at any constant throttle, and not going over 3/4 open either do this for a while and you will be on your way to ripping it up again!! GOOD JOB!!!
