so i have one motor with a siezed shift drum and another motoe with bad tranny gears and i can't seem to figure out how the shift drum comes out of the cases. any help would be helpful. i also can get pics if needed.
thanks,
EVan
thanks,
EVan
1985 suzuki alt 185
1985 honda atc 250sx
1985 honda atc 200m (all apart)
1984 honda atc 200es
1984 honda atc 200x- need motor, plastics, axle, exhaust.
1984 honda atc 125m- times 2
1985 honda atc 200m all apart
1983 honda atc 200e times 2
1983 honda atc 250r-times 2
1983 honda atc 200 4 parts
1983 honda atc 110 times 3
1979 honda atc 110 smokey
1978 honda atc 90- restored
Have lots of extra parts, if interested email at e_mcy@hotmail.com
You have to split the motors to change the shifter drum. It's a pretty big job to do it.
Howdy
i have the engines spit already and the transmission partly apart, but i can't get the shifter drum out of the case what holds it in there? i'll get pics tomorrow
1985 suzuki alt 185
You have to unscrew the pin on the left side of the motor. The pin I am reffering to is the one that goes to the netraul indicator button. #9 in this fiche ( see link ).Originally Posted by zoomerman
http://www.bikebandit.com/partsbandi..._id~190825.asp
Howdy
i can't believe i never figured that out, oh well thanks alot howdy. I got the bottem end put together that took almost all day now all i have to do is get new rings
1985 suzuki alt 185
