Results 1 to 7 of 7
Thread: exaust leak on a triz
    mnnmaz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2006
    Arizona (USA)
    222
    Question exaust leak on a triz
    I have an 85 triz with a DG pipe and silincer my question is, how do you stop the oil comming out of the front where the pipe mounts to the jug. I have the two inserts that come with it and I purchased three new spring but it still leaks and I dont like cleaning oil off the front of the jug every other rid any ideas to solve this???
    Original 85 TriZ owner
    Certified NASA welder PM me if you need any welding I do extended swingarms and everything you can dream of
    Three is Always better then four, unless its with women then four is better then three
    Apr 2006
    c.square, new york
    77
    exhaust leaks
    Their is a productcalled chamber seal it costs 7.00$ and you can get it from rocky mtn atv.its a high temp.sealing tape you wrap around your exh. flangeand makes a nice tight seal.
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    High temp silicone works good also, I used it on my 1985 ktm 125 and will probably do the same on my 1991 ktm 540 when i get it going.
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
    Ontario, CANADA
    4,538
    Most guys use high temp RTV silicone, the orange goop. Works good for a few months then reapply. Or at least in my case, but also I put alota hours on my machines.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    RTV orange is a better way to go than the exhaust tape. I have tried both and the RTV worked longer than the tape.
    Adam
    89 LT500R-
    85 250R- Project-
    85 250sx-
    83 185s
    80 act70
    I use orange rtv nice thick bead put the pipe on and let it sit over night to fully cure..might take a few time to get it right
    Mar 2004
    194
    Yeah the Orange RTV is what i was referring too. Make sure to clean the area which it is going to stick to VERY well.
    -1983 Honda ATC110-
    -1991 KTM 540-
    -1996 KTM 550-
    -1997 Honda Cr80-
