Results 1 to 15 of 17
Thread: axle nut wrenches??
    Feb 2006
    Central Florida
    1,090
    axle nut wrenches??
    I have a serious axle nut problem on my hands and have been looking for a set of axle nut wrenches.
    I see the short ones on ebay for 30-40 bucks but I dont know how well they work..
    anyone know where to get a set of the longer ones? or ever use the short ones?
    also - anyone have a neat tool for the tri-zinger axle nuts?
    atc wrenches on ebay: ( the only ones I can find) http://cgi.ebay.com/ebaymotors/Motio...QQcmdZViewItem
    r4r
    quiet people seem intelligent
    Jul 2006
    I just take a cheap large cresent wrench adjsut it to fit well, then weld the hell out of it so it stays, 5 bucks at the dollar general!
    Jun 2003
    englishtown NJ
    2,676
    You can't use a pipe wrench for them???? I always used a pipe wrench for the axle nuts on my honda's. I used a pipe wrench on my friends yfz, banchee and my old warrior.
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    i use a pipe wrench that has a pipe welded on it.. works like a charm!
    Nov 2002
    Kirkville, NY
    3,831
    I use a pipe wrench too, most of the time I slip a long pipe on the end to make it even easier. The only thing is it chews up the nuts a little so don't use them on a show bike.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    Yep, I use a pipe wrench aswell. Gets those nuts loose. I am going to give the welded up crescent a go aswell.
    Maryland
    3,077
    Go to sears and buy the right size wrenches. They sell big ones, and they're not too expensive.
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    I forgot to mention, if you cannot get that axle nut off, get the angle grinder out and cut through the axle nut and chisel it off.
    Feb 2006
    Central Florida
    1,090
    ha - I have done that before but its no fun... it takes a minute and is such a pain
    no one has used the short wrenches?
    the one i am working on is a rear end that is dismounted. that seems to make it even harder. I put it in a vice earlier and closed it as tight as I could... still started turning in the vice... until my channellocks exploded and hit the wall!
    i would of thought the pipe wrench would have worked on the zinger ring nut because its round but it just started cutting into the nut.
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    The short wrenches don't have much leverage.
    Feb 2006
    Central Florida
    1,090
    you think they would be ok if I welded extensions on them?
    burnoutboy's Avatar
    Apr 2006
    New Zealand.
    352
    They should be fine.
    Nov 2006
    southern oregon
    2,338
    Find a friend with a large high-quality crescent, why weld it? adjust it tight and break it loose...
    2-stroke lover
    Feb 2006
    Central Florida
    1,090
    I hope it doesnt have to come to that... i am going to keep trying on these for a while and will post the outcome.
    if anyone has a set of the longer wrenches they will part with I am looking..
    tired of chopping
    Jan 2005
    Wasteland Michigan
    149
    the short ones are ment to be used with a 1/2" breaker bar and torque wrench. i bought mine from rocky mountain atv they have there own line of tool and are inexpensive too ( mine cost $20 ish )
    larry
    RIDE SIDEWAYS
    got another addiction
    Honda's
    86 ATC 350X
    T/F Survivor 06 / 07
    SANDPUPPI Survivor 07 / 08
