Results 1 to 13 of 13
Thread: compression spex and check.. wet or dry
    Feb 2006
    Central Florida
    1,090
    According to the specifications page and the haynes manual I should be seeing about 180 PSI compression on my 1983 110.
    I went and checked earlier and I got about 100-110 on the 4th pull when dry.
    I put a tablespoon (or half quart) in the cyl and checked it again reading almost 200 PSI.
    Are the specs for a wet test?
    If not I got a prob
    quiet people seem intelligent
    Apr 2006
    Crestview, Florida
    2,429
    dry i would imagine. try running it up to temp first.
    Feb 2006
    Central Florida
    1,090
    going once.....
    will check it next time i ride it too Eric - shes blocked in by a couple projects...
    (Im scatterbrain'd)
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    i don't know if this aply's to 2 strokes but your suppost to hold the throttle in the wide open state while testing the compression. but first you should run your engine for 10 to 15 minutes then do a compression check.
    some one will correct me if i'm wrong.
    I'v never really did a compression test on a 2 stroke.
    daputz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    a proud cheese head
    207
    Normally you test the engine cold, unless specified in the manual.
    The dry vs wet is a way to tell if it is the ring or valves on a 4 stroke. Take your 1st measurement dry (compare to spec in manual) then add the oil, if the compression greatly increases the rings are on the way out...................if the compression stays the same with the oil added the you have valve issues.
    yes cold and with the throttle open
    Feb 2006
    Central Florida
    1,090
    ok -
    this is a fresh bore with new piston and rings. any idea why it would be so low?
    I will check it again with the throttle open when i get a chance - but what does that do? alow more air into the intake valve?
    you reckon i did not break it in right and ruined the rings? thanks
    Feb 2006
    Canada
    36
    If you have put a new piston and rings in it and you still get a low compression reading, maybe your cylinder wall is scratched or there is something wrong with your valves. Does it run great?
    Aug 2004
    Ab Canada
    4,368
    110's dont have much compression-even new......i woudlnt worry about it, if it runs fine.
    1985 Tri-Z-
    Feb 2006
    Central Florida
    1,090
    yea - it runs fine - but it is a little slow. I figured if it was not making enough compression that might slow it down some... ( but I have not ridden a 110 for 10+ years until I built this one from *Edited**Edited**Edited**Edited**Edited**Edited**E dited* parts)
    both the dry and wet test showed absolutely no leakdown in a 20-25 minute timeframe - so I would assume the valves are good. they are brand new as well..
    Feb 2006
    Central Florida
    1,090
    the word that got editied was an adjective for a person with no father... lol - I didnt know I could not say the b word!
    Nov 2002
    Kirkville, NY
    3,831
    Yes cold dry and with the throttle wide open. Opening up the throttle all the way will give you a lot more air; you should see the compression reading go up significantly. As for the 110 being slow, well that is why they made bigger machines, the 110 is a good machine and does lots of things well but going fast is not one of them (or at least in stock form).
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Feb 2006
    Central Florida
    1,090
    ha - thanks fox... you just shattered my dreams!!
    its not totally stock! I have that super badass cobra exhaust on it - lol
