Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: atc 500r carb
    Masshole
    2,191
    atc 500r carb
    Here is a pic
    Nov 2006
    southern oregon
    2,338
    have you tried it without the reed spacer? Are you set on using that mikuni? Keihins are much more compact.
    2-stroke lover
    Masshole
    2,191
    Its hard to see in the pic but the carb actually will hit the top motor mount the way it is even with the spacer. I do have a keihin 39mm that came with this motor but it is currently on my other "r". Problem still remains the boot is angled up a little and will cause havoc with any carb i think. I also have a stock 34mm keihin that i tried and had the same problem
    Nov 2006
    southern oregon
    2,338
    Why is the spacer ontop of the reed cage? Is that just for mock-up purposes?
    2-stroke lover
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Make an insert out of billet, for the intake then extend it to your desire with the same diameter as the outlet of teh carb. Then clamp it all down. Use a rubber fittig with clamp.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Masshole
    2,191
    i thought about that, but would that cause havoc with the distance of the carb to the reeds? And yes ithe spacer is just mocked up temp. I just had a brainstorm though, ill try making an angled reed spacer that is 1.5 inches thick at the top and 1/4 inch at the bottom that will level things out maybee. Off to the bridgeport!!!
    Nov 2006
    southern oregon
    2,338
    Maybe there is a different intake you can use. I think there are multiple atc's with 500's in them on here. I am sure that some of these owners will log in later on.
    2-stroke lover
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Your gonna have to fabricate a custom aluminum angled intake with a rubber boot for the carb to slip into it looks like. Although now looking at it I'm not sure thats the answer. Maybe you could make a new one and angle more towards you(from the picture) where its kind of almost a side mount. Not sure what that would do for flow though. Either that or use a carb that isn't as tall.
    Jun 2002
    Mississippi
    2,552
    how did you mount that engine? it looks like that is the problem. my carb fits great!! and the mikuni should be your last choice for a 500.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    3leggeddog's Avatar
    Nov 2004
    lets see some pics of how you got the motor mounted.does your pipe fit?are you running the swingarm bolt throught the rear of the engine?i will get pics of my 500 for you,i don't have any clearence issues.i am sure your motor is mounted different,but you may want to rethink the way it's setting.surely you can make it fit without modding the intake.all my stuff is stock cr 500,in an 86250r frame.fits like o.j. simpsons glove,and i can maintence everything in the bike.i can check the plug,remove the carb,whatever.let me get some pics.,and please post some more of your pics
    3leggeddog's Avatar
    Nov 2004
    oand if you need a pipe,let me know.i got a modded dg cr500/250r pipe layin here.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    here is mine,,, pitch that carb its to big,,, i even have the stock intake boot on mine,,,, with lotsa room to spare,,, i am also running a rad valve ,,,
    KASEY's Avatar
    4,246
    there is a comparison,, you got a wild motor angle going on there ,, lets see some wider angle shots,,, something ain't right in there .... whats that copper line for ? need input,,,
    Jackson MI
    1,688
    Kasey, I can tell by the look of your front sprocket that you did some work to the bottom of your frame. The chain hits the slider perfectly. Looks sweet.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jun 2002
    Mississippi
    2,552
    here is mine also. you can see the rear of the engine looks lower.
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
