Thread: 1984 atc200m bent axle easy fix?
    Dec 2006
    New Brunswick
    41
    Ok, this is the issue. When i adjust my chain to the desired tension it does not stay that way.If i roll the bike slightly forward it goes loose again and if i roll it forward some more it gets tight again.I assume the axle is bent.The only other possibillity in my mind is irregular wear on the sproket,or a bad berring(i should be able to feel this.right?) So anyhow i read somewhere that a bent axle can be fixed. Just bend it back or what? and is there a trick to this?
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    i doubt a bearing would cause it to get as loose as you describe... and i also doubt the axle being bent, the sprocket is soo close to the center of the axle, if it was bent enough to effect the chain slack, then the three wheeler should move and shake pretty bad when you ride it... not sure how the chain adjustment is set up on those but i'd imagine its a sprocket...
    Dec 2006
    New Brunswick
    41
    Thanks Tyman that makes perfect sence now that i think about it. the ride is smooth so mabey i will start with the sprockets. and a fatass chain. endlessly adjusting the chain.
    thanks again and this site kicks
    Mar 2004
    Saint John NB, Canada
    146
    my old 200 had the same problem. It was a broken frame right behind the rear wheel (chain side). the frame would flex and throw the chain.
    "And I bled out of here, and here, and here and here.........."
    '84 200M-Cobra pipe-sold
    '99 honda 300 fourtrax-2 inch lift, Bearclaws on ITPs
    1981 honda 185s-Ole Smokey! :
    1987 Honda 250x....well in theory
