Results 1 to 12 of 12
Thread: Swapping around front end pieces...
    ATCR250R's Avatar
    ATCR250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Norfolk, NY
    319
    Well as I continue my build of my 1984 250R I have discovered another pleasent surprise. When tearing down some remaining early X parts I found I have an aftermarket ENKEI 1085 aluminum wheel for the front and already mounted on it is a nice like new trailwolf tire. Anybody have any opinion on these wheels? I think it is a 2 piece and I looked up the company now and it seems they still make wheels for the import car crowd mainly. Here are a couple pics of the wheel and the 250R wheel...
    Aftermarket Wheel
    Close up of where the pieces come together and thickness...
    250R Wheel
    Also, lastly I was trying to decide which front disk to use. I know I will have to use the X hub for the Enkei wheel but I have a choice of the two disks since both will fit. (BTW I plan on using the X front caliper and braking system as well) On one hand the left one has 4 drilled spots in each line of them as the right side one has a 4 then 3 pattern. Another thing is the design in the middle. I am still not sure even though I know the right one would have to be cleaned up well. Please let me know what you think and sorry for the long post... Thanks!
    ATCless at the moment...
    1977 Firebird Formula
    1997 Suzuki RM250
    ATCR250R's Avatar
    Norfolk, NY
    319
    Oh, and one thing I forgot, are the rim stops shown on the left hub necessary or not? I only have two of them and would like to not use any. Thanks again!
    1997 Suzuki RM250
    Jan 2005
    Jones, Michigan
    1,821
    um
    I thought most honda rims were enkei? or atleast alot of the front rims ive seen are
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    ATCR250R's Avatar
    Norfolk, NY
    319
    Hmmm, well maybe you are right but I thought they were all D.I.D. That and it being in such nice shape and around twice the thickness of the R wheel makes me think it was aftermarket. You may be correct but either way thats the one I want to use on my 250R. lol
    1997 Suzuki RM250
    Nov 2006
    Florida
    1,663
    My front wheel is by enkei, 11incher too
    PA
    3,515
    the black rotor is a front 350x rotor ....they will interchange
    WWW.HREATV.COM
    PA
    3,515
    wtf???
    thats odd
    WWW.HREATV.COM
    ATCR250R's Avatar
    Norfolk, NY
    319
    Alright then, I guess the only questions left then are why would the X have a seemingly better wheel? Was it a weight issue? Though you would think they would want it to be stronger... Also which disk which you choose if it matters?
    1997 Suzuki RM250
    Mar 2004
    Saint John NB, Canada
    146
    I would use the disk on the left, I think the slots in it look alot cooler then just the holes in the one on the right.
    "And I bled out of here, and here, and here and here.........."
    '84 200M-Cobra pipe-sold
    '99 honda 300 fourtrax-2 inch lift, Bearclaws on ITPs
    1981 honda 185s-Ole Smokey! :
    1987 Honda 250x....well in theory
    ATCR250R's Avatar
    Norfolk, NY
    319
    OK, I have asked a couple other people and the 350X disk will be used... Last thing is any info on those rim locks? Thanks again everyone!
    1997 Suzuki RM250
    Jul 2004
    miami, fl
    91
    Honda used 3 vendors for rims DID,Enkei, and forget the other. Probably whoever would anodize them gold at the cheapest price.
    I am unsure by the picture of the hub regarding the rim stops, a larger pic might help or explain in more detail what you are trying to ask
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    If you are talking about the tabs behind the studs on the hub, you don't need them.
    I'm not even sure why they put them there, since the lug nuts are tapered and will self-center the rim,anyway.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
