The front tire on my 1985 200s has a chronic flat. Tried to take out the front axle but the axle is siezed in the shock. Tried heat with more heat, impact wrench, breaker bar ect. hasnt budget it. got the tire off anyway by taking it off the hub and pullling it by the shock. Now i cant break down the front tire, tried tires and evan a shop press on the bead. How are you ever supposed to break these tires down. Next problem was that I tried to get the shock out of the forks so i took the 2 bolts out, but know the shock wont come out of the forks, moved it a little but put some pretty good scratches in it and i am afraid i may have ruined it. Anway to sum up my list of hardships I cant break down the front tire to fix it, axle is siezed into the shock housing, and the shock is stuck in the forks, and help would be more than welcome. Thanks
