Results 1 to 7 of 7
Thread: 1985 TEcate Problems!
    El Paso TX
    65
    I cant get this bike to run the compresion is good and everything not sure if the coil,flywheel are working!the flywheel is rusted and cant take it off!Help me out!
    Nov 2006
    Florida
    1,663
    COuld be the flywheels and stator.. we had that problem with our 84.. ran great one day wouldn't start for *Edited**Edited**Edited**Edited*.. If your flywheel is rusted means there's water in there and my mean your stator is shot.. Is there spark from the plug? Take the plug out, leave it attached to the coil wire.. place it on the head where you can see the bottem, with your hand turn the motor over (using the kickstart) if there ain;t no spark your stator is done.
    El Paso TX
    65
    were can I get a used stator or flywheel?
    Nov 2006
    Florida
    1,663
    Try the classifieds on the forum here, I'm sure somebody might have one of them.. If not ebay would be your next best shot. Post a thread in the classifiends first though, I've had losts of luck on there myself.
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Look and see if you have spark first.
    You can get a ricky stator.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Newfoundland
    5,280
    Flywheel key may be sheered as well.
    Oct 2005
    saratoga, ny
    2,819
    can you get the flywheel off with a puller?
