Both the axle and the bearing carrier are different between the 85 and 86 right?
I've got an 85 with a Durablue axle in the stock bearing carrier. I'm considering replacing the carrier but I'm not sure what I should be looking for.
thanks
thanks
Get a 85 Bearing Carrier ( if that what you need & have ), 85 & 86 are Different....
hey guys i kinda need to know for my project, are the 85-86 axles different? Im also looking to buy an 85 carrier if anyone has one.
Kevin
- Chick McGee
-1985 250sx
- 1986 atc310R drag bike
- 1981 110 chopper.
- 1985/6 350x
- 2-84 atc250r's and 1 83
- 2002 trx400ex
- 1985 atc 250r
-1985 atc70 WTB PARTS
- 1985 tecate
I know LSR still makes one for the 85 but its pricey compared to the 86/89. You may want to look into RAD if your looking for an aftermarket carrier, might find it cheaper if they make the 85 model.Originally Posted by GPracer2500
Heres LSR's at $231.00
http://www.lsracing.com/honda-250r-parts.htm
Just looked on ebay and there is one by RAD for the 85, search honda 250r carrier. Theres actually 3 of them listed for the 85, one rad, one lsr and one without a name.
What is the difference between the 85 and 86 carrier??
The 85 carrier has a smaller outside diameter, if you were to put it in a 86/89 swingarm it would be too loose.Originally Posted by jeffatc250r
http://cgi.ebay.com/ebaymotors/RAD-B...spagenameZWDVW
hope this link works....the difference is the area ware you ajust the chain...see how thin this 85 carrier is
here is a 86 style http://cgi.ebay.com/ebaymotors/Honda...70588343QQrdZ1
WWW.HREATV.COM
Oh ok, i have wondered about that. i guess if you got a good deal on an 86 carrier you could hog down the od of the carrier if you have access to a lathe. Do the axles interchange??
id guess the sprocket hub is offset different since the 85 carrier is thinner on that side.
but i never messed with the older style....i just noticed the adjustment area difference
WWW.HREATV.COM
that would not work it.s a big difference. just get the he one swigin showed in the link. $135 is a deal.Originally Posted by jeffatc250r
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
Originally Posted by SWIGIN
I won that one--$127.50. I got a RAD axle lock nut too--$49.95. After shipping, $191.82 for both. Probably don't need either piece but oh well--it's only money, right?![]()
