Results 1 to 15 of 27
Thread: Math Equations...?
    Mar 2004
    Hillman, MI
    21
    Math Equations...?
    Hi Everyone, I'm looking for an equation(or series of equations) for a circle that, given a distance traveled around a circumference(distance in mm the center of the lower crankpin travels), and referenced to a start angle(port open angle) and an end angle(mean port duration) will give me a vertial distance travelled. I've been searching for a while now, and haven't found anything of use. I was hoping that someone here might be able to point me in the right direction. I'm working on a spreadsheet that does some of the more tedious math for me when determining the state of tune on a given 2 stroke engine. This calculation would help me determine the distance from the top of a given port the mean area line is located at. I can then calculate mean port area, and so on and so forth, without making a physial drawing and calculating with a t-square and protractor. Any help is appreciated, thanks.
    Tom
    Cooter
    85 ATC 250R
    WANTED: PT High Rev and Fat Boy Silencer
    Jan 2004
    Palmetto,Florida
    2,300
    WOW !!!!......... HECK all's i do is use my finger to check thing's when Porting ...
    the common thing is 1.5-2 mm's up on the Exhaust and 2-2.5 Wider at the TOP
    TROLL has the Macdizy thingy for that mess ............
    "07" DR650 Suzuki Dual Sport
    Mar 2004
    Hillman, MI
    21
    I found it on MacDizzy.. figures.. look for two hours and finally ask a question... ten minutes later you stumble on it.. thanks anyway guys.
    Tom
    Cooter
    85 ATC 250R
    Columbia
    5,131
    Dang, first post and you've been here for 3 years!
    What do you ride?
    Mar 2004
    Hillman, MI
    21
    I have 1 and a half ATC250R's. I'm workin on a new dirtbike for next summer. I don't post much, but I read a lot.
    Tom
    Cooter
    85 ATC 250R
    Feb 2006
    Central Florida
    1,090
    theres a cooter lurkin out there... yikes!
    you never posted the formula..
    quiet people seem intelligent
    Mar 2004
    Hillman, MI
    21
    In spreadsheet form HT=(r+c)-(rcos(a))-sqrt(c^2-(rsin(a))^2), where
    HT= piston height
    r=stroke divided by 2
    c=con rod legnth
    a=crank angle, in radians
    d=crank angle, in degrees
    dtor=degrees to radians = PI/180
    a=d*dtor
    And if we know this, we can then extrapolate, from the change in piston height, where, measured from the top of the port down, the line that represents the mean area of the port lies. Assuming you have measured port duration, and a few dozen other things correctly.
    Cooter
    85 ATC 250R
    Feb 2006
    Central Florida
    1,090
    you using this instead of a flowbench to test how a port will flow?
    thanks for sharing..
    rcos is a little confusing .... I started breaking it down like r*c*o*s
    so is rcin...
    Mar 2004
    Hillman, MI
    21
    Yes, in the end I want to be able to input several easily measureable parameters, port width, shape, port duration and calculate sizes of ports to determine the state of tune. I'm trying to learn to port the right way without several hundred dollars worth of software. So far i'm on the right track. My neighbor has a yz250 that I did that'll come right over if you crack it at 45mph. I've done a couple others with overall good results.
    Cooter
    85 ATC 250R
    Feb 2006
    Central Florida
    1,090
    i hear ya bro, its all about making the big money spendin fools look bad
    when you get your measurements down just right you should make metal templates that slide into the ported head and sell them to us dummies- that way we can port ours to perfection and not have to do all the work!
    Nov 2002
    Kirkville, NY
    3,831
    What is involved in the flowbench testing? I have heard about it but how does it actually work?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    daputz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    a proud cheese head
    207
    you found your hook up
    Macdizzy is where you need to be if plan on using the different porting sofftwares and proven timing and durations. Nothing there is free but they will always point you in the right direction.
    Feb 2006
    Central Florida
    1,090
    I like cooters method for porting better - I will even port blind - i dont really care. i can not answer your question very good but basically strap a head to the bench with the equipment attached to it and put some air over it. the equipment will put everything on a PC screen for you to analyze - in differ colors so you can tell when you improving or not.
    grind, test - grind, test.... send owner large bill to make payment on your equip.
    this is an injector, but it is similar to the readout
    Mar 2004
    a proud cheese head
    207
    Quote Originally Posted by thefox
    flow bench testing is great......................but you need to know what you are looking for to begin with. Do you want volume or velocity? at what range? what duration?
    Here is a ques..........................when someone adds material to port/head to get a desired result (making the port smaller instead of hogging it out changing angles...) is it still considered to be porting?
    Mar 2004
    Hillman, MI
    21
    Of course its still porting, it takes the same amount of calculating to come to the conclusion that more material is needed in a certain area. Whether its for the purposes of streamlining airflow, say transfer tunnels, or the floor of a port on a four stroke, or optimizing air velocity for a desired RPM. Adding material is often MORE time consuming because of the need to weld in layers, or epoxy layers to reach a rough shape, and then start cutting/sanding to create the final port shape.
    Cooter
    85 ATC 250R
