Results 1 to 15 of 53
Thread: SYKO flat tracker IS READY!!!!
    Jul 2006
    Thumbs up SYKO flat tracker IS READY!!!!
    well I almost got my flat tracker ready for next weekend (jan 20th) all I need to do (today) axle bearings, remove front tire, tighten up a few bolts, get a few bolts, and finish mounting my nerfs, the motor runs super sweet, and I'm jsut crossing my fingers right now that I dont get Billy's luck
    the mods I did are more to the rear suspension than anything, I decided not to use the factory shock and get a lowering link, instead I fab'd up a mount for the shorter 200x shock, also since its not on a linkage the shock dosnt operate by leverage, and is alot harder than my factory 250R shock on a linkage system, it only sags about 1 inch with me on it (225lbs) and still has 2 inches of travel, the shock will bottom before my machine, unlike before. also I had to lenghthen my air filter intake, but that was no big deal, oh and if your woundering the front tire is going tomoorow I will have my shorter, less agresive tire on there. I also added renthal twin wall bars (wich I got for 20 beans!! new!!) with moose adapters (thanks raffa!) they raise the bars up just right and dont hit the gas tank at lock, wich I still have to trim a little off the stops yet.
    now I got to pick up my numbers (thanks billy!!) add a few more stickys (got 2 3 ww stickers on there right now REPReSENT!!)
    future plans are a 10 inch front wheel, wider rear end and a few other changes, but nothing major
    Attached Thumbnails Attached Thumbnails MVC-741S.JPG   MVC-742S.JPG   MVC-743S.JPG   MVC-744S.JPG   MVC-745S.JPG   MVC-746S.JPG
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Sweet! GIT R DONE!
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,245
    i have a few numbers if you need any,,, also have you given any thought to using 2 spring setup on the frontend? then you can put the short spring on top of the dampening rods,,, them run forks in the stock position? safer if you happen to go over the bars,,, just a thought,,, i like the rear suspension mod too,,, i think it will work great,,,,,
    Jul 2006
    I apreciate that kasey!! but I'm going to get one of my X's (she works at a sign shop) to bust me off a few for me, for the free! and since the race is next weekend I dont want to take any chances of waiting on somehting in the mail, My buget for this was very low, I havnt spend maybe 250 in the whole thing (including engine work) to get it to this point, I cant wait to rip it up!!!
    also I jsut removed my short spring up front, and since the forks still have a fresh rebuild on them I think I will be ok, but... only time will tell!! if I do bail, I do it in STYLE!!!!
    KASEY's Avatar
    4,245
    ohhh, not good!!! when you don't put the short spring in,,, when you gas it you get full extension on the front forks ,, which gives you a light frontend to high,,,, where as when you put the spring in... it limits the travell and gives you the weight of the front tire wheel and hub sooner and helps keep it down, sooner,,, been there ,,, set on your trike,, take a rachet strap to the roof and have someone pull it up,,, you will see how high its going to get when you come out of a corner with the power on,,, especially when your *Edited**Edited**Edited**Edited**Edited* is over the brab bar trying to get traction,,,
    Jul 2006
    10-4 good buddy!! it will be put back in!!!
    KASEY's Avatar
    4,245
    are you going to use those rear tires?
    Jul 2006
    yea, those tires are easy for me to break loose on the turns, hoosiers may hook up to much plus if they slide then they will wear out quicker and since its a trike of course we got to slide!! and spending mulla on a set of tires every few races isnt my idea of fun, and these are readably available and cheap. oh and case your woundering they are waaay over inflated right now
    Nov 2006
    Tulare, California
    719
    Those rear tires are bad. I want to get some for my 350x.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Dec 2006
    St. John's Newfoundland
    1,587
    Good luck man. You gonna get this on vid?
    Oct 2005
    saratoga, ny
    2,819
    carlisle links rear tires, like butta baby. sweet looking trike psycho.
    KASEY's Avatar
    4,245
    i think you should groove them ,,your going to need more traction than those will give you,, to help equalize them in the turns,, i would do a 1/4 groove at a 45 degree angle every 20 degrees on the outside tire and maybe every 30 degrees on the inside one,,, plus stager air pressure a few pounds,,, theres more to going fast than just spinning around having fun,,,,
    Jul 2006
    well finnaly tested this thing, man its stupid!! I pulled a couple high speed drifts on the pavement at a intersection close to my house in 5th gear!!, a little more vibration in my handle bars than what I want, and the front tires sucks right this minute for it but all that will change this week.
    Columbia
    5,131
    Looks great Syko!
    Newfoundland
    5,280
    What nerfs are those??
