i have a 79 110 with stock bore and aftermarket exhaust (DG) and ct90 intake with a 24mm carb. i just bought a new carb and was wondering what size jet i should use the stock one is suppost to be a 82 jet. i dont know what is in the new carb cause i dont have it yet but any ideas would be great! or is it a deal whgere you have to ride it too see? the reason i bought a new one is it would die when i shift into gear but if i did get it into gear it would spudder befor it took off does that sound like too much fuel or too little i will check the jet in this carb now. also a mikuni tear down pic would be great im pretty sure the main jet screws into the bowl but not sure
