What are the differences in the 81-82r motor vs the 83-84r motor? My friend is looking for a spare bottom end for his 84. Will the 81-82 motors drop in?
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
the motors are pretty much the same other than the shifter output shaft is longer on the 81-2 and the 83-4. Now if he can get a hold of an 83-4 transmission it will drop right into the 81-2 bottom end and then he will be set to go.
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
