Thread: 200R wiring help needed
    Mike Fort Laud's Avatar
    Mike Fort Laud is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2002
    386
    My first step to getting the 200R up and running is wiring. The bike does not have the wiring harness, switches, coil, voltage regulator,rectifier or any lights.. I can buy a harness and all electronics on ebay for next to nothing, but do I need a complete harness. I will not put lights on it, so I do not need the handlebar switch or lighting wires. All I want is a race style handlebar mounted kill switch with a cord to shut it off. All I have for wires is the wire coming from the stator cover that goes to the coil. Can somebody give me a little info on what I need to do. I want to keep this bike with the bare essentials only needed to race. I want to know what I need and what I don't.........Thanks
    I would rather have a sister in a whorehouse,than a brother with a quad!!!!!!!!!!!!!!!!!!!!!! Still walking the "Tightrope"
    Feb 2002
    386
    Just pulled the stator cover and this thing has a MotoPlat Ignition. I may have to send it to Bradford Ignitions for a little freshen up job. It is 22 years old.
    Aug 2005
    HI
    1,575
    what is the difference in the ignition?
    Rest in peace Rex Carlson
    Jun 2002
    Mississippi
    2,552
    there is a 250r race PVL set up on ebay right now. i would just buy that and be done with it.
    really all you need is a CDI, coil, stator, teather, and the voltage regulator. you can build your own harness.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Apr 2003
    Central New York
    1,860
    Wiring Harness
    When I did my Tecate I had the same situation. I used the diagram on the manual and parts from E-Bay and a Trike Graveyard. Worked out sweet, and didnt cost much. Do you have a manual? For the a 200R I would use the best goodies I could find.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
