alright, so i got this t3 motor in from ebay, took right apart to check it out. lots of good parts on it, as far as i can see the only bad thing is the rod bearing is crapped, tiny metal chunks in the bottom of the crank. new crank and seals and bearings, with a new rod and bearings. no biggy. the clutch in it looks brand spanking new, the impeller is like new, it was good to at least see that. then i decided to start looking at the top end on it. nice 84 kx cylinder, will need a sleeve though i think, or get it re nicked. right now its not nikasil lined, it has a cross hatch hone job on it, so more then likely it was resleeved? for now the question is, when i pulled out the reedcage, the intake boot is glued to the reedcage, cant seperate it. and it looks nothing like my stock t3 cages i have laying around. heres some pics, maybe someone has an idea of what type reed cage it is....thanks in advance guys.
