Starter on the way out maybe?
Do you have a decompression lever?
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
yes, yes i do, it's how i found out that my exhaust valve setting came undone one day on the trails, it was like no valve was there when i lifted up and down on it, lots of free play in it.
thats some thing else to when i pull it over it has enough compression to tear my fingures off,
I am not sure what the sound is. Have you tried listening to your engine? Put a piece of tube up to your ear and put the other end against the case. Move it around till you hear the sound. Kind of a shot in the dark but you may be able to narrow down where it is coming from more accurately that way.
As for the starter motor they are notorious for wearing out. You may just need new brushes, pull it apart and see but be careful with it. Also when re-attaching the cable make sure not to over tighten the nut that holds it on.
$120 for rings and gaskets? I would get the Yamaha rings and aftermarket gasket kit. I don't know how much that would be in Canada but Yamaha rings here are about $30, and another $20-$30 for a top end gasket kit.
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Originally Posted by thefox
Thanks, as for the noise i'm about 95 percent sure it coming from up by the starter, if there was a way i could pull the start off and run it with out it that would be great. but it would make one heck of a mess of oil...
Originally Posted by troy
I had the same problem with my 85' DRN225. My starter was bad. It would not turn the motor over fast enough to start it. I bought a starter off ebay, start's great now. A new starter should solve your problem. Good luck
